removing tar from trunk...Fire or Ice ?
  • george graves
    • 20003
    Just called the ice place - it only $1 a pound for DRY ICE....
    I was thinking it might make quick work of the sound deading in the trunk of my '89 'is.
    Who has experence in removing the tar slabs with fire or ice?
    Thanks!
    George Graves
    Originally posted by Matt-B
  • rwh11385
    lance_entities
    • 18403
    The e30m50.com guy, Mark I believe, told me how he did it. Heat gun and putty knife. Then mineral spirits on the residue.
    • george graves
      • 20003
      What exactly are "mineral spirits" - is that like mineral oil?
      • Avus_325is
        • Mar 2004
        • 446
        It's like paint thinner.
        • e9nine
          • 1890
          Re: removing tar from trunk...Fire or Ice ?
          Thanks!
          George Graves
          If the weather is hot, wait till around 1pm or so take a putty knife to it and see how easily it comes out. Mine came out without the use of any fire, ice or whatever. You can use the degreaser to clean the sticky residue if any remains.
          • bimmerphile
            • 3495
            yeah i spent a day using dry ice on my neighbor's track car
            he got home, left the car in the sun, and did easily 3x the work i did in 4 hours.
            • clavinZERO
              Hella sick E30
              • Mar 2004
              • 2027
              what kind of dampening difference are you going to notice without it? beacause i hear that it weighs quite a bit and wud be a nice weight reduction.
              "BMW Style 32 Poster-Child"
              HTTP://WWW.CLAVINZERO.COM/e30-5-lug
              **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
              • george graves
                • 20003
                I'm sure I'll replace the weight with some tools, emergency parts, dead bodies...(oh forget that last one) - Baby a sub-woffer, ect...You can always add the weigh back in for better stuff...
                George Graves
                • e30Matt
                  • 5077
                  You do know that the tar isn't just for sound deadening... it's for weight balance. The cars are biased to the front in weight and the tar is there to even things out. Removing it will increase the "tail happiness" of your car.
                  • rwh11385
                    lance_entities
                    • 18403
                    Tail Happiness? :P Sweet.
                    • clavinZERO
                      Hella sick E30
                      • Mar 2004
                      • 2027
                      is that wieght THAT big of a difference to effect weight balance SO much?
                      • bimmerphile
                        • 3495
                        Its a big enough difference to warrant removal isn't it? :idea:
                        We're talking a good 100lbs worth of stuff back their (at least that would of my neighbor's 325iS). In our cars, that's a hefty chunk of weight. Then when you consider rear seat, spare tire, rear deck, etc removal, you've substantially decreased the car's overall weight.
                          • 34844
                          actually, it would make your car understeer more, because the end that is lighter sticks better. :)
                          • e30Matt
                            • 5077
                            It's all about weight transfer. When you brake entering a corner, where does the weight go? The FRONT of the car. If your car doesn't have anything holding the rear end down, it's going to try to lift. If you don't believe me, come drive my 325i. I did this, and it's easy as hell to spin on a rainy day now. I (sorta) regret it, but I'm not driving it anymore, so I don't really care all that much.
                              • 34844
                              uhh, you're not supposed to break when you enter a corner anyway, unless you're trail braking your left foot should be on the floor!
                              if you're just turning into a corner (as you should be in an E30, not braking, which would send many cars tail first), a car with a heavier front than rear will understeer more than one with even weight distribution.
                              This is bad on a 6cyl E30 because you are already front heavy. Unless you're doing this for drag racing or extreme weight reduction (ie track only car), it's probably best to concentrate on reducing the front end of the car (ditch the AC, cf hood, etc), where the weight loss will actually help handling. :)
