Go let your car sit for a long period of time (like overnight) and try starting it with the ICV unhooked if you don't believe me. :P
I'm saying bend the contacts because it may've gotten on the contacts in there, clean it up, bend them down a bit, it's a common wear point, bending them makes it pull smoother most of the time anyway, it's very easy, nothing you can break. Just seal the lid back with some silicone or whatever you have that will seal it.
There may just be a flat spot in the idle portion, mine had this problem rather suddenly with a crappy idle and crappy high throttle, the contact had just worn itself from the sweeping.
