I was just wondering if the mpg needle reads off of the OBC? If not where does it get its reading?
MPG needle
I think it does more than that cause at time, my foot can be dead steady and the reading may vary by the incline of the road or wind conditions. I may be wrong here..
One reason for me to believe 325iCabrios answer is becuase with passengers you may notice the same indication while "technically" economy should suffer.
The ECU has a harness that goes to the gauge cluster which has a harness that goes to the OBC. I'm not sure if the gauge cluster is a pass-through for the OBC or if it has an effect on the signal as it goes through. I assume it's just a pass-through and it pulls the instant MPG signal off of this.
The OBC only receives 3 things for MPG calculation: the speed pulses (from the differential sensor), the injector pulses (from the ECU) and the calibration factor (from the per-engine-type module).
So if the injectors are clogged, the O2 sensor will notice a lean mixture, the ECU opens the injectors longer, and the ECU will then tell the OBC/gauge cluster to report a higher fuel useage number (LESS MPG) even though you aren't necessarily getting worse MPG.
If you are going up a hill, and keep EXACT throttle input the same, your road speed will decrease, injector timing will remain constant, and you will get less MPG since you are traveling less distance with equivelant fuel use per second.
Originally posted by JGood View PostThe ECU has a harness that goes to the gauge cluster which has a harness that goes to the OBC. I'm not sure if the gauge cluster is a pass-through for the OBC or if it has an effect on the signal as it goes through. I assume it's just a pass-through and it pulls the instant MPG signal off of this.
If you are going up a hill, and keep EXACT throttle input the same, your road speed will decrease, injector timing will remain constant, and you will get less MPG since you are traveling less distance with equivelant fuel use per second.:jk: :up:
I believe that it reads the MPH directly off of the speedo and then calculates that against the RPM. When I was having problems with my speedo, the MPG needle would go to 0 every time the speedo stopped working. Also, I notice that when the car is coasting at a speed that is consistent with the engine the needle remains around 25 but as soon as the car is coasting faster than the engine, almost to suggest that the car is pushing the engine, then the needle goes to the extreme left past 40.
I don't really know how it works, but in mine (i have an M10), when i bought it, it had lots of hoses disconnected, and the needle was not working, I replaced all the hoses and it came back to life.
It "feels" like a vacuum meter, when i coast at 30mph, mine says 7 liters every 100 km. if downhill it says 2-3 liters.
But it doesn't work when the car is not moving :p
so go figure how it works...
Originally posted by ivo316 View PostI don't really know how it works, but in mine (i have an M10), when i bought it, it had lots of hoses disconnected, and the needle was not working, I replaced all the hoses and it came back to life.
Gauge cluster sends the mpg reading to OBC.Current:
BMW 320i 2d 2.0 m20 -88
BMW 325i Cabriolet 2.5 m50 -88
BMW 316i touring 1.6 m40 -90
BMW 320i 4d 2,2 m54 -01
Originally posted by Jscotty View PostI believe that it reads the MPH directly off of the speedo and then calculates that against the RPM. When I was having problems with my speedo, the MPG needle would go to 0 every time the speedo stopped working. Also, I notice that when the car is coasting at a speed that is consistent with the engine the needle remains around 25 but as soon as the car is coasting faster than the engine, almost to suggest that the car is pushing the engine, then the needle goes to the extreme left past 40.
It is not relative to engine speed, only injector pulses and road speed, both defined and sent to the cluster by the ECU, combined with the calculation factor plug. The reason your MPG needle max's out past 40 is because you actually are getting that many MPG. You are using as much fuel as you would use at idle, while coasting, but since you are coasting at 40,50,60 whatever mph, do the math - that is alot of MPG.
Originally posted by JGood View Postinjector pulses and road speed, both defined and sent to the cluster by the ECU.Current:
Originally posted by Rocla View PostRoad speed is measured by cluster from diff speed sensor, and is sent from cluster to ECU for max. speed limitation, if present.
