trying to get a parts list for the manual swap...
  • natorious
    • 672
    what parts to do i need to get this swap done...
    i would love to just get a parts car but i have no place to put one so thats not gonna happen...
    here is what i have on the list so far
    e30 tranny
    driveshaft
    center bearing
    guibo
    transmission mounts
    flywheel
    shifter platform
    pedal assembly
    what else am i missing
    what hydralic components am i missing?
    clutch master and slave?
    are sedan and coupe drive shafts the same?
    will an e36 transmission fit...
    what is the best LSD to swap in while i am doing this
    the car is an 89' 325i sedan with 4HP22 auto-tragic
    hopefully i can get all the parts and start installing it mid-april
  • Bill 84 318i
    • 1600
    Parts I'd get...
    New:
    Clutch assembly (disc, throwout bearing, pilot bearing, pressure plate, pivot pin)
    Seals (engine rear main, tranny input, tranny output, selector shaft)
    Guibo/center support bearing
    Shift assembly bushings
    Tranny mounts (and engine if they haven't been done in awhile)
    Master/slave cylinders
    Flywheel bolts
    Pressure plate bolts
    Used:
    e30 (Getrag 260) transmission and rear mounting bracket
    Driveshaft (yes, coupe and sedan are the same size)
    Clutch hydraulic lines (solid one from MC to 2nd line, rubber/solid one from 1st line to slave)
    Pedal box
    Flywheel (get it resurfaced)
    Shift console (maybe a new Z3 short lever to go with it)
    Disclaimer: may have forgotten something, but pretty sure that's it.
    I think it's easiest to get it all off one car, personally. Lots of small differences between models and years.
    • m42technic
      • 1056
      *cough*TJ*cough*
      James Peacock
      WWFSMD?
      • M-technik-3
        • 18946
        Originally posted by m42technic
        *cough*TJ*cough*
        :D I'm beginning to think he can't drive a standard shift car. ;) Mine drove me nuts so it's gone, see ya automagic.
        • kencopperwheat
          King of Kegstands
          • 14396
          Contact Ryan ('super_eta'). He's got all the parts necessary for a 5-speed swap and he's looking to unload them.
          His AIM s/n is Ryan325eS
          Originally posted by Gruelius
          • Super Eta
            • 1884
            Yes i am and will let everythin go for 350+ shipping with new driveshaft.
            Beware that shipping all of this wont be cheap. :?
            • natorious
              • 672
              sending you a PM
