interesting. Seemed the common consenus was somewhere around 18 pounds, i wonder how the guys that shaved theirs and got all these lower numbers attained them consistently.
Lightened flywheels?
I think trent sells the same one Turner does
E30 325i 1987-91 Lightweight Flywheel
Part #: 520060
Applications: 1987 - 1991 325i (E30)
Flywheel weight: 8 LBS. Stock flywheel is 16 LBS.
Price: $399.95Comment
BUT CHAPEL YOU BROKE THE BUBBLE. We are modifying factory parts and hoping to spend under 200 bucks. I am trying to find my 323 flywheel right now so I can weigh it.
w
LOOKS GREAT JORDAN.
some more information.
metric mechanic says 12 pounds @$250.00 (as low as 8 with a 215 320 flywheel)
Tep says 14 pounds @$160.00Comment
I just got back from the machine shop, and my flywheel is home.
13lbs, $90.
https://mtechniqueabs.com/Comment
Jordan,
what kind of place did u take it to, and what did u say to them. "hey, here is my flywheel, lighten it." or did u give them the plans and waht u wanted it to look like and stuff?
im fairly interested in doing that. 90$ is a DEAL.98 M3/4/5
The parts modeling, and mass calculations were all done in Autodesk Inventor R5.3
Solidworks is shit, used it, hated it, threw it away.
No, sorry, I won't be "sharing" a $5000 software suite.
EDIT: Sorry, misread your post. No the file is not open to use.
I brought the 3D cross-sections, and detailed dimentioned parts drawings to the shop, and said lathe it down. Their job was easy, and they commented on it. They wish more customers showed them EXACTLY what they wanted done.
It was just a normal machine shop, and shop with a large lathe can do this work.
Here is a sliced cross-section. The red shows material that was removed.
not the package. the file for the flywheel
I just would like to have the flywheel file, not the whole autodesk package.
Autodesk makes shit, I used it, hated it, threw it away. ....to each his own. I can design products pretty fast in solidworks. We just got 2004 last week, and I as IT guy get to install it on a gazillion desktops next weekend. yay.
butbackontopic:
I am interested in a dxf or iges or stl or parasolid file. It's evidently not too complex of a machining job, I just think that your model is cool. Thanks--Comment
Good job dude. missing my target by only a pound was great. I think you broke your model by 5 pounds. My flywheel said 18 pounds on the bathroom scale. Don't know how accurate that is but it is a 323 flywheel and the teeth for the starter seem different location compared to yours (teeth vs mass of wheel)
wComment
