replace bitch clip with 1cm bolt?
  • ptownTSI
    • Jun 2005
    • 1265
    so if the bitch clip is .392" in diameter...0.392 inch = 0.99568 centimeter, which is close enough to 1cm, can I replace the bitch clip with a bolt? I just ordered the AKG 75D poly bushings for this.
    i searched for "replace bitch clip" and didnt find anything, so help me out if i glanced over something and missed it.
  • turbo_negro69
    • Dec 2006
    • 468
    why? I still don't know why its called "the bitch clip". It's not that hard to remove and replace. I'll post a picture of the tool I use to to it. It's like a hook dealy with one end twisted a bit. damnit i don't have a picture of it on my computer. i'll post it tomorrow.
    *edit for pic*
    91-318i SOLD : (
    91-318IS for sale
    95-740i DD
    84-Monte carlo SS Under construction
    90-T-bird Supercoupe DD
    • AndrewBird
      The Mad Scientist
      • 11898
      Jordan did:
      More pictures here:
      • ptownTSI
        • Jun 2005
        • 1265
        on another thought...did they really raise the cost of a shifter by $20?? at the start of the shifter thread they were $43, now they are $62 from pelican for a Z3 1.9 or Z4 2.5...those were the only ones i checked.
        • ptownTSI
          • Jun 2005
          • 1265
          stock manifolds?? http://oldmary.lqhome.com/%7Ejordans...album=59&pos=8
          • turbo_negro69
            • Dec 2006
            • 468
            jordan also cleans the underside of his m3 like he's a speedfreak thats been up for the past 3 days and has nothing better to do:loco:
            91-318i SOLD : (
            91-318IS for sale
            95-740i DD
            • AndrewBird
              The Mad Scientist
              • 11898
              Originally posted by ptownTSI
              That was before he did his stroker and got headers. That picture is of a stock M20B25.
              • DaN
                • 1265
                I'm running a bronze bushing and a bolt like jordo. Shifter is nice and tight
                • Dave
                  E30 RAT
                  • 11675
                  Any idea what size/length of bolt he used there?
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • Schneider325
                    • May 2004
                    • 3818
                    It has become the mod that everybody does and is one of easiest with great benefits.
                    Basically the Demand has gone up through the word of the community. That is only a guess though.
                    • James Crivellone
                      Head Janitor
                      • 6305
                      I just use the stock bitch clip.
                      With a custom brash bushing I machined.
                      • Rocla
                        • 922
                        Distance between the mounting flanges is ~25mm so about m10*40 or m10*45 bolt should do... make sure that bolt has threadless area.
                        Longer bolt is easy to trim to correct lenght.
                        Current:
                        BMW 320i 2d 2.0 m20 -88
                        BMW 325i Cabriolet 2.5 m50 -88
                        BMW 316i touring 1.6 m40 -90
                        BMW 320i 4d 2,2 m54 -01
                        • gstuning
                          • 833
                          I used a bolt and shims,
                          the bolt goes into the hole on the trans, then trough a shim, then the shifter carrier, then another shim, then trough the trans again, and a nut on the end,
                          if you have the perfect sized shims that are large enough too stop the movement of the carrier it will not budge at all, I tightened it with the nut and bolt,
                          the bolt width has nothing do to with anything I did, it just has to it trough the holes on the transmission
                          Gunni
                          @ Prodrive / Aston Martin Racing
                          • DJB
                            • Oct 2005
                            • 195
                            Doesn't the M3 already use a bolt with a keyed head instead of the bitch clip: http://www.realoem.com/bmw/showparts...81&hg=25&fg=05
                            • browntown
                              • Jun 2004
                              • 3524
                              I destroyed a nose picker (radiator hose tool) like the one turbo_negro69 uses, honestly now that I've done it I can probably tackle the bitch clip much faster, but it seems a much better idea to use the bolt with some thread locker and good shims or bushing. Taking a mental note. Good idea.
