HVAC fan not tunring off
  • rwh11385
    lance_entities
    • 18403
    Help. I'm at home for the weekend, and it's cold, so of course I'm running the defrost. But when I turned the key off, the fan does not stop. I fear that it is stuck on and my battery will wear down because that is what someone told me would happen. I have to turn the knob to "0" and then it will stop, but I would ratehr have it be so I just turn the car off and I am cool.
    Has anyone else experienced this at an earlier point in time? Or anyone have an idea of why this is happening.
    please helpp
  • O 16581 72452 5
    • 1066
    It happened in my car, a few off and on turns of the key (from off into first click) and it shut it down. I'm assuming a stuck relay, problem isn't limited to this car, a buddy had a Taurus beater this happened with too.
    I no longer have 1 2 and 3 of my blower intensity after this happened, only 4 works, i haven't traced why, been too cold.
    • kommissar
      • Dec 2005
      • 402
      Sorry this doesn't help you lance, but O 165...
      You have a blown resistor pack. Part number 19 in the diagram. Replace or maybe clean it and you should be set.
      Full page of parts.
      • O 16581 72452 5
        • 1066
        I'm not even sure what i'm looking at in that diagram, appears it may be the actual blower motor?
        • kommissar
          • Dec 2005
          • 402
          I guess it doesn't matter, you're banned now!
          But for anyone else that is wondering, it in the blower-motor area.
          • rwh11385
            lance_entities
            • 18403
            oh yeah, well my 1,2,3 also stopped working a while ago, but it didn't really affect me. Is that a step towards the HVAC fan continously running, or just another failed or dirty peice of electrical wiring??
            The relays are under the hood right? Is there one for the HVAC that maybe got screwed up and I can just replace? OR WHAT IS GOING ON?!??!
            p.s. Banned boy advice did not work
            thanks for anyone who can aid me
            • Dave
              E30 RAT
              • 11675
              you're fucked dude.
              just part it out.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • kommissar
                • Dec 2005
                • 402
                The 1-2-3 blower motor intensity is probably not related to the fan not turning off. Sounds like you have two separate issues here. The resistor pack controls the different speeds of the fan by altering the resistance in the circuit. When it stops working correctly, you only get fan speed 4 and 0 (usually 0, in your case not). If you replace it you should get back the 1-2-3 settings.
                It is located in the center of the firewall behind the intake manifold. You pop off the two nuts holding the wires to the firewall, unscrew the 4 bolts holding the cover on, and remove the cover. You will see it sitting below the blower motor.
                • rwh11385
                  lance_entities
                  • 18403
                  alright, sounds good, but that wasn't really a huge concern.
                  having the fan not shut off with the car is more than just inconvienant. It could leave me stranded if I forget to turn the knob to "0". I'm going back after the Bears game to school, so if anyone has something for me to try before then, let me know. Or actually, afterwards too and I can just order parts and get to it later.
                  thanks
                    • 34844
                    have you fixed it? most likely it's a bad relay. I went through this same issue after my 5 speed swap. I used some bad wiring instructions for the tranny wiring and it shorted something out, and fried one of my relays. my fan was also stuck on when I turned off the key.. I tested everything else with no luck, and ended up swapping the relays that control the HVAC motor with a spare and that ended up being the problem. otherwise it could be a short, but relays are much easier to check.
                    • rwh11385
                      lance_entities
                      • 18403
                      I hadn't, but was thinking the problem was along those lines. Your post encouraged me to go outside after finding a little more info (actual relay location) and do it.
                      Find information, resources and relevant links for bmwe30.net. This domain may be for sale.
                      Had a spare in my glovebox after replacing a good fuel pump one I thought may have been a past running issue, and it turns off when the ignition is off. score.
                        • 34844
                        sweet :)
                        • kRonX
                          • Aug 2004
                          • 144
                          Sorry to dig up an old thread but this is happening to me right now and the site is no longer working. Anyone know which relays to replace and where it is located?
                          • rwh11385
                            lance_entities
                            • 18403
                            I'm not sure... it's been a while. But there should be a diagram somewhere online or in a bentley, if not an owner's guide.
                            • kRonX
                              • Aug 2004
                              • 144
                              Do you remember if it was one of the relays in the fuse box in the engine bay by the driver side strut tower?
