problem with overheating ix
  • kansas-ix
    • Jan 2004
    • 1600
    tonight drove the ix 50 miles and then when I tried to return, went straight to hot, and no heat in the inside, I know your thinking thermostat, but it works fine, boiled it and everthing to check, just replaced fan clutch recently and everything worked fine before tonight, so I was thinking, blockage somewhere, or radiator, any other options or is there a definite solution based on this? thanks in advance.
    E30 325ix 62k
  • bmwguru007
    • 561
    Easiest and most probable solution is the cooling system needs to be bled.
    • kansas-ix
      • Jan 2004
      • 1600
      fyi was bled when I did the fan clutch two weeks ago,
      E30 325ix 62k
      • bmwguru007
        • 561
        I would suggest bleeding it again before looking elsewhere. No heat is a telltale sign of air in the system.
        • AndrewBird
          The Mad Scientist
          • 11898
          Is the radiator/bottle filled? Sometimes air can get trapped and will take a few days to work its way out. Also, not sure if it is possible on an E30, but did you put the fan on backwards? Knew someone who did that and had over heating problems until he figured out what he had done. :roll:
          Andrew
          • Jordan
            • 12916
            Turn the heater all the way on, and go bleed the system. Fill it up some more, then go bleed it again.
            e30 fans cant be put on backwards, just wont work.
            and the fan only cools the engine while it is standing still. Once the car is in motion the fan is entirely not needed.
            https://mtechniqueabs.com/
            • AndrewBird
              The Mad Scientist
              • 11898
              Yes, but if it was on backwards and turned while moving, it would push air away from the engine. But since it won't do that on an e30, move on.
              Andrew
