whats the best chip to get on the 88' super eta. would the 85-87 tms chip work on this particular car? thanks
super eta chip
Tags: None
I have the Turner chip for my 87 eta and it is great. Nost sure if it will work with your car. I don't think so.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed. -
Someone makes a stroker chip, intended for an "i" cam and 19lb injectors.
Do that with the correct cam and dual valve springs.
LukeComment
They don't make a chip because that particular model was only produced one year 88 325 and 88 528e so they didn't see much of a market for it. I had heard that an I chip works but I tried it and it didn't start. This was back in the day when I ECU's were expensive. These days you're better off starting with an 'i' ECU and of course swap the cam and valve springs, intake manifold/TB."I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
88 M3 - LACHSSILBER
89 M3 - ALPINEWEISS II
91 M TECH CABRIO 2.7L TURBO - MACAOBLAUComment
i top end & ECU = happy 88 325Comment
Just get a 173 ECU and put in the MarkD 325i chip. You'll feel the difference with the ECU alone and the chip just enhances the difference.sigpicComment
where can i get that 173 ecu? what car does it come off of? and where can i grab the markd chip? guaranteed functional with my car? what type of additional power am i looking at once this is done? also can someone clarify the alpina b3 2.7i(which is supereta) chip? ive read up so much i cant recall where i read it from but thats supposably the chip to get for the super etas, or am i mistaken? thanks a lot for input and advice guys. BIG HELP!!Last edited by e30hereicome; 01-22-2007, 08:23 AM.Comment
The 173 ECU is from the 325i. There's one in the For Sale forum right now. Go to www.dsylvatech.ca for your chip. Yes its all compatible - I drive a Super ETA that I just swapped an 'i' cam, intak, throttle body and some other stuff into. Its essentially a 325i now.where can i get that 173 ecu? what car does it come off of? and where can i grab the markd chip? guaranteed functional with my car? what type of additional power am i looking at once this is done? also can someone clarify the alpina b3 2.7i(which is supereta) chip? ive read up so much i cant recall where i read it from but thats supposably the chip to get for the super etas, or am i mistaken? thanks a lot for input and advice guys. BIG HELP!!sigpicComment
