RPMS drop too slowly
  • brandondan1
    • 1091
    Hi, I just got done replacing my starter. I ended up cleaning some electrical contacts while I was at it.
    After starting her up, I noticed that after I applied the throttle and let off, the revs would drop VERY slowly, stop, drop slowly, stop, until it hit the idle point.
    Is my ECU just trying to get adjusted or is something else to blame?
    91 318is
  • MikeE30325i
    • 2356
    hhhmm, sounds puzzling. did you mess with any throttle linkage or anything? maybe bend a bar when you were moving around, causing the problem?
    • brandondan1
      • 1091
      Well, I checked the throttle cable and it seems to be fine. I get the same response whether I blip the throttle from the cabin or under the hood.
      91 318is
      • MikeE30325i
        • 2356
        Hhhmmm, then the problem is more complicated than i thought. sorry, but i dont have any experience with this. good luck on fixing it.
        • brandondan1
          • 1091
          Np. Thanks anyway.
          Btw, I'm also getting hesitation off idle if I press the gas too hard. Dunno if this is related.
          91 318is
          • StereoInstaller1
            GAS
            • 22679
            Vacuum leak?
            Closing SOON!
            Thanks for 10 years of fun!
            • NC325iC
              • Mar 2004
              • 6565
              could still be the throttle linkage too tight or the throttle set screw holding the throttle open some, but if you didnt mess with the throttle linkage at all then its unlikely that it would have changed
              • bddog
                • 351
                Santiam Pass been there. Silver Falls are awesome.
                A shredded wire inside the throttle cable can do it, especialy after an old one has been moved around.
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  Check your idle control valve. May be time to clean that thing.
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • JGood
                    • Jan 2004
                    • 7959
                    Yeah, I second the ICV. How does it idle otherwise?
                    Check all your connections and wiring, make sure you didn't pinch wires or leave anything unplugged.
                    I highly doubt it's the throttle cable or linkage, if you actuated the throttle body from under the hood you would see it return to close very slowly instead of snapping back.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • brandondan1
                      • 1091
                      Thanks guys. I cleaned out the connections on the ICV, and after about 30 minutes of driving, it's back to normal.
                      91 318is
                      • Garageaholic
                        • Dec 2005
                        • 5204
                        out of curiousity, how did you "clean it"? i need to clean mine as well. Thanks!
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        • HST
                          • Jan 2006
                          • 757
                          I just used carb cleaner untill in was moving freely and without a gritty feeling. Mine was really bad.
                          Originally posted by KingB
                          Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                          • RobertK
                            Kicked cancer's ASS.
                            • Jun 2005
                            • 5864
                            Also check your throttle cable for binding especially at the firewall. Sometimes the shielding cracks at bending points and exposes the cable. I've had it happen to me twice.
                            • HST
                              • Jan 2006
                              • 757
                              Don't just clean to conections, you need to clean the inside of the ICV itself.
