What would cause a heater to not blow hot?
  • psloan
    • 9815
    The car is a 90 325i - the heater blows warm when stopped and cold as can be when the car is moving. I'm assuming the heater valve is stuck closed? I can hear a flap close or something when i turn the heat knob - so im assuming that's not it. Any ideas?
  • jbsjunk
    • 477
    I'd start with a t-stat. Sounds like it's stuck open.
    • psloan
      • 9815
      I guess that would explain the car running under the half way mark all the time. I'll swap it out.
      • BimmerToad
        • Sep 2004
        • 1537
        did you mess with the hoses going to the heater core? After my swap, I flipped the hoses to the core and didn't get nearly as much heat as I wanted.
        San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
        • e30frosh
          • Dec 2004
          • 2170
          I would guess the t-stat as well. I had to drive without mine for a while as to not overheat.
          Every day I wake up we drink a lot of coffee and watch the CNN
          Every day I wake up to a bowl of clover honey and let the locusts fly in.
          Lobsterbacks attack the town again
          Wrap all my things in aluminum
          Beams of darkness streak across the sky
          Pink rays from the ancient satellite
          Every time I look out my window same three dogs looking back at me.
          Every time I open my windows cranes fly in to terrorize me.
          • mrsleeve
            • Mar 2005
            • 16387
            I would say t-stat is a good start. bet that fixes it
            Originally posted by Fusion
            William Pitt-
            • Mr Deagle
              • 1121
              a clogged core would also do that
              • mrsleeve
                • Mar 2005
                • 16387
                true, but lets start with the easy stuff 1st, and he said his car was running cool
                William Pitt-
                • Mr Deagle
                  • 1121
                  what about the recall thing that goes inline between the engine block and the heater core? that is supposed to close so the heater core does not blow up if the car overheats
                  • StereoInstaller1
                    GAS
                    • 22679
                    Just before the heater core is a small valve. Ball style, it does a great job closing water flow to the heater core. It is electrically controllled, and closes when the A/C is on.
                    It is intended to make the coolant circulate only through the block when the A/C is on, which explains the odd block bypass circulation hoses under the throttle body.
                    Mine stuck shut, making no heat. I was too broke to replace it, so I drilled it out. Bad idea, BTW. Cheap but shitty!
                    Your car may be suffering from the same thing.
                    GL, HTH,
                    Luke
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • psloan
                      • 9815
                      I 2nd dayed a t stat from bavauto. I'll see if that helps.
                      • brandondan1
                        • 1091
                        GL, HTH,
                        Luke
                        +1
                        91 318is
                        • psloan
                          • 9815
                          GL, HTH,
                          Luke
                          How hard is it to get to if the t stat doesnt help?
                          • psloan
                            • 9815
                            Is it #7 on the 2nd pic or # 16 on the first pic?
                            Thanks guys
                            • psloan
                              • 9815
                              I'm looking at this - those are 2 different heater assemblies. Which is most likely on my car? I guess i can worry about it when the tstat doesn't work.
