The speedometer side of the dash appears to have no lighting. I believe the light bulb on the speedometer side of the dash may have blown, but I am not sure. I haven't taken the dash out yet to actually check, but I been told that if the bulbs are gone, you would need to get it from a dealer and not somewhere like kragens or autoparts. Is that true? Also if I do have to get the bulbs, I was wondering if there are specific part numbers that go with it, just so when I walk into the dealer, I don't walk in clueless. Thanks.
Dash Light, one side on.
Try tapping your dash. Happened to me at the same spot, probably 4 years ago, and for the second time the other night when I attempted to drive my car when it was 4 degrees outside. I just give the clear plastic a few taps and it comes right back.
If you did blow a bulb, I'm not sure where you could get one. Try a search on here for "dash bulb" or something.Comment
