interior courtesy light delay
  • Nick
    • Oct 2006
    • 279
    Some have it, some don't.
    Mine does. :D
    • fretburnr
      • Jan 2005
      • 1496
      Originally posted by ryno
      my lights turn off when my door closes. There's no delay.
      mine has always done this.
      Jay
      • fporro
        • 1860
        Originally posted by fretburnr
        Hey Frank - i'll take one of those. i'll be sending paypal shortly.
        Got it Jay, thanks.
        shipping it today., I'll PM you tracking #.
        sounds like a slick mod. whats the duration of the delay with these Frank?
        Ryno, It sure is a sweet upgrade for those that don't have it.
        5 second timer.
        Mine does. :D
        And some just burn away, like the Central Lock Modules do.
        for those that requested pic, here's it's tested drawer.
        Most of them were manufactured by Hella, BMW part # 1 373 974 ...
        or 975 (with secondary removable clip on bracket)
        and or by Wehrle / BMW # 61 31 1 380 231.2
        for those of you with cabrios / iC, fuggetaboutit ., i tried but wiring is not same as in coupes, sedans or wagons.
        (edit: i stand corrected, they do work on cabrios too, see follow up posts)
        • fretburnr
          • Jan 2005
          • 1496
          Thanks man :)
          Jay
          • micahbertoli
            • 76
            so how do i know if my car came with the delay relay in the first place, but maybe it just wigged out on me (without checking part # on the relay because i'm tired!)?
            • 325iCabrio
              • Jun 2006
              • 485
              My cabrio has a delay relay. Works great.
              1988 325ic Automatic
              • fporro
                • 1860
                uhm, would you happen to know the part # ?
                both my cabrios won't Time Delay. odd.
                no matter how many relays i swap into 'em. 8(
                • 325iCabrio
                  • Jun 2006
                  • 485
                  I'm not positive, but part # 61 31 1 373 974 is listed on RealOEM (#2 on the diagram). I've never taken mine apart because I've never had a problem with it.
                  • micahbertoli
                    • 76
                    fporro,
                    payment sent for interior courtesy delay relay.
                    thanks
                    ryno,
                    where are you in Coquitlam?
                    i'm in the Cape Horn area; haven't seen your e30 around
                    • onaquest
                      • Nov 2005
                      • 805
                      como lake/ blue mtn area.
                      my name is onaquest on bimmerclassics
                      http://bbswheels.blogspot.com
                      • fporro
                        • 1860
                        uhm, thanks, # 974'si9 got plenty of, so it must be something in the A pillar connectors.
                        thanks again.
                        Originally posted by micahbertoli
                        fporro,
                        thanks
                        received it, thanks.
                        shipping it today via U.S. Postal Service, will PM you details.
                        thanks again,
                        Frank
                        • asubimmer
                          • 6482
                          someone wanna take a pic of where it is? I need to get new door sensors anyway, my int lights don't turn on unless I pull out that switch
                          • 92 mtechnic cabrio
                            • 4907
                            just noticed, mine still works, at 145k miles, yar har har suckers!
                            this made me happy :)
                            R.I.P 07/01/09 - 04/23/10 :(
                            • fporro
                              • 1860
                              THAT'S IT !
                              marching out in my PJ's to give it another try ;)
                              • BimmerBall
                                • Oct 2006
                                • 185
                                for those who may still be having problems with their interior light delay, i discovered my problem was the drivers side exterior door handle switch. according to the wiring diagram it has has an note: "Timer is enabled when driver's exterior door handle switch AND any door jamb switch close..." {every time you open the driver's side door you're working this switch connected to the door handle} So, instead of tracking down a switch and pulling the door panels off, i just grabbed a quick splice:
                                simply lay the two wires you want to splice side by side in the quick splice, take a pair of pliers and squeeze down on the metal tab (which pierces the insulation, etc). and close the plastic cover.
                                I looked at the wiring of the relay socket and spliced the brown/green wire (door handle switch) with the brown/yellow wire (door jamb switch). Works great.
