interior courtesy light delay
  • micahbertoli
    • 76
    i have a '91 318is, and my interior courtesy lights turn off when i close the door (thus breaking the circuit by pushing the door pin in)
    i know that some e30's have delayed interior courtesy lights that stay on after the door closes for a certain amount of time.
    how can i mod this for my car?
    is it just a matter of splicing in a simple circuit board?
    any suggestions?
    thanks
  • NC325iC
    • Mar 2004
    • 6565
    a capacitor would be needed i think
    • Mr Deagle
      • 1121
      two ten watt bulbs, it would need a lot of capacitance to work for any length of time
      • george graves
        • 20003
        shrug...
        Originally posted by Matt-B
        • Jean
          • 18228
          An extra relay to control your lights, a basic delay circuit or maybe even a cap of big enough size (still will be much smaller than one need to be in parallel with the bulbs) in paralell with a relay coilto keep the relay ON (and keep your bulbs on).
          • fporro
            • 1860
            I have about 60 of them BMW OEM timer relays, (courtesy light function)
            if you like, send me $ 25 buckaroos and I'll put one in the mail fer ya.
            paypal: fporro (at) msn (dot) com
            • AdamF 88iS
              • 2051
              Your timer relay may have just gone bad. It's down below the driver's front speaker next to the door lock control unit.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • micahbertoli
                • 76
                so how would i wire that in? just splice it into the wires that go to/from the door pin?
                if so, i'd be interested. shipping to BC, Canada? V3K 5H8
                • fporro
                  • 1860
                  it just plugs into same socket that original relay sits in., remove...
                  - Hood realease handle, 2 x 8mm with 1/4" socket wrench
                  - Speaker Cover / Kick Panel, 1 phillip screw
                  - Speaker, 3 phillips screws
                  - Plastic cover below speaker opening,
                  - Timer relay module bracket, 2 big / brass colored phillips screws, wiggle it up, becareful or you'll cut your self.
                  you'll see relay next to Central Lock Module unit., swap Dimmer relay and you're done.
                  make it $ 30 since your in Canada.
                  cheerios,
                  frank
                  • fretburnr
                    • Jan 2005
                    • 1496
                    Hey Frank - i'll take one of those. i'll be sending paypal shortly.
                    Jay
                    • onaquest
                      • Nov 2005
                      • 805
                      sounds like a slick mod. whats the duration of the delay with these Frank?
                      http://bbswheels.blogspot.com
                      • 92 mtechnic cabrio
                        • 4907
                        READ man, it's not a mod, it's the OEM relay replacement
                        R.I.P 07/01/09 - 04/23/10 :(
                        • onaquest
                          • Nov 2005
                          • 805
                          depends on what your definition of mod is. to me its short for "modification.
                          currently i have a non delayed relay installed, switching to a relay with a delay would be considered a mod.
                          thanks for coming out.
                            • 34844
                            didn't E30s already come with this? at least mine did..
                            • onaquest
                              • Nov 2005
                              • 805
                              my lights turn off when my door closes. There's no delay.
