Car shakes wildly at 62 mph only wtf?
  • MikeE30325i
    • 2356
    mine used to wobble like a fucking retard at about 50 mph. then i balanced my tires and it went away.
    • DarkWing6
      • Apr 2004
      • 7144
      He already had the wheels/tires balanced. How many people are going to tell him to check that after he said in the first post that he had already done that?
      Things to check (pretty much already stated) wheel bearing, CAB, outer tie rods, etc. All those bushings holding everything together down there. If you are going to be doing suspension all of those should (except the wheel bearing) be changed anyways.
      If you put the car up on jack stands shake the wheel and see if there is any play. Also look at the bushings and see if they are bad.
      • 2002maniac
        • 4260
        switch the wheels front and back and see if it makes a difference. Might as well try the easy stuff first.
