Heater sucks
    • 37832
    Heater sucks
    Ever since the i swap my heater has only been luke warm, anybody know what the issue may be?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • backtrail69
    • Jul 2005
    • 4471
    Did you get a cooler thermostat? What do you need a heater for in SoCal anyhow...
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • AdamF 88iS
      • 2051
      Do you have the heater lines hooked up right? The outlet from the head goes to the lower pipe on the firewall, the upper pipe is the long return hose to the thermostat housing.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • Dave
        E30 RAT
        • 11675
        BRING BAcK HEEtER!!!!!!!
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
          • 37832
          Yes, the same one that my turbo car had in it. The heater in that car kicked ass.
          Grover Beach, CA
          www.BimmerHeads.com
            • 37832
            Aren't the hoses different sizes. I doubt I reversed them. I will check tomorrow.
            Grover Beach, CA
            www.BimmerHeads.com
            • JeffR116
              • Jan 2007
              • 140
              Burp your cooling system again?
              • Garageaholic
                Freestyle Fabricator
                • Dec 2005
                • 5204
                ^^^ I second that. I think you have air trapped in the system somewhere. When you bleed the coolant, Raise the coolant reservior well above the engine. It should help in summoning any water bubbles out of there rather than having the reservior at the same level as the engine.
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                Instagram.com/garageaholic
                Youtube.com/garageaholic
                • rede30
                  • 4697
                  so you do this when you loosen the bleed screw?
                    • 37832
                    I have bled it twice now [while holding the reservoir nice and high] but I guess I will have to try it again.
                    Grover Beach, CA
                    www.BimmerHeads.com
