Trunk tool kit - what can you fix?
  • george graves
    • 19998
    Exactly what did bmw have in mind to be able to fix with *just* the trunk tool kit?
    Originally posted by Matt-B
  • backtrail69
    • Jul 2005
    • 4471
    I removed my oil level sensor with the 10 mil wrench when all my tools were at a different location to clean it. I have fixed a few blown charge pipes before as well with the screwdriver. My parts car came with a trunk full of tools as well... that was a good find.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • lordofthewaters
      • Oct 2005
      • 714
      I've pulled my plugs with the plug wrench........
      Sarcasm is a body's natural defense against stupid.
      When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
      "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
      Old age and treachery will always overcome youth and skill.
      • delatlanta1281
        Dart Master
        • Mar 2006
        • 10317
        My e28 tookit rocks. Everything on an e30 that would be possible to fix on the side of the road can be addressed with this kit.
        Yours truly,
        Rich
        you kids get off my lawn.....
        • erik325i
          • Jan 2005
          • 3567
          You can fix anything with the trunk tools.
          A few times I went to the junkyard to pull some parts, but realized I forgot my tools. I had to use only my trunk toolkit to pull rear swaybars, foglights, interior pieces...
          -Erik
          • rs4pro3
            • 5808
            ya I put the larger e34 style kit in my car, and do a ton. But the old e28 and e24 kits are the largest.
            85 325e 2.7 ITB'd stroker
            • RobertK
              Kicked cancer's ASS.
              • Jun 2005
              • 5864
              One time I rebuilt a M20 with my trunk toolkit..
              No rly
              • e30_325es
                • 1249
                I adjust my shocks with my tool kit pliers. I've also pulled my rear shocks off w/ the wrenches.
                  • 34839
                  if you don't have a clutch fan, I think it's enough to do a water pump and timing belt..
                  • e30 gangsta
                    • 3877
                    Fixed my blown altenator belts with the bmw glovebox flashlight my shoelaces and the tool box in the rear.
                    • Charlie
                      kid tested, administrator approved
                      • 6686
                      Given the state of most e30 tool kits, adjust anything that needs a 13mm wrench, line up a wheel, and spend half an hour trying to figure out what the hell goes in the spot for the convertible socket.
                      -Charlie
                      Swing wild, brake later, don't apologize.
                      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                      FYYFF
                      • Tangent
                        • Mar 2004
                        • 476
                        Close power windows and sunroof if the motors fail...
                        • turbo_negro69
                          • Dec 2006
                          • 468
                          I restored my entire monte carlo from the ground up with my e30 trunk tool kit!
                          91-318i SOLD : (
                          91-318IS for sale
                          95-740i DD
                          84-Monte carlo SS Under construction
                          90-T-bird Supercoupe DD
                          • 87-325ic
                            • Apr 2006
                            • 1198
                            all i ever use from my toolkit is the screwdriver, not much else is there,
                            and now my screwdriver is lost somewhere..
                            • DJB
                              • Oct 2005
                              • 195
                              You need a 3mm hex key to remove the rotor, 5mm hex for the reference sensor, 13mm socket on a 2"-3" extension to remove the crank pulley bolts. You could probably fake the 22mm wrench to turn the crank and 32mm flat wrench for the fan with the slip-joint pliers.
