Control Arm Bushing Install - Help!!!!
  • mdv
    • 61
    I got the old bushings off the arm no problem, they slid right off. Pressed the old bushings out of the bracket and the new ones in. I can't for the life of me get the stupid things back on the arm! I tried lots of soap and water, grease, motor oil you name it. I can only get the things about half way on. Any ideas?? Do I need a special tool or something. I've read all these posts that say soap and water do the trick. What am I missing??? :x
  • Bill 84 318i
    • 1600
    Drill a hole (3/4"?) in a 2x4. Start the bushing on the control arm, then whack the 2x4 with a BFH (while using lube). It'll take a couple good whacks but it'll go on.
    • mdv
      • 61
      Thanks. I'll give that a try. Hopefully I have enough room with the arm mounted on the car.
        • 34844
        you need lubrication, and lots of it! dish soap and water works well, if you still can't get it on use more soap.
        • Bill 84 318i
          • 1600
          Is it a M3 or regular e30 bushing?
          If it's a regular bushing, I used this method and it worked fantastic (~5 seconds).
          Attach the line, walk to the front of the car, and jerk like mad. Slid right on.
          • mdv
            • 61
            I bought the M3 bushing. Thanks for the pic, it gave me an idea. I don't think I'll be able to put enough pressure on it with a rope. I did try a wood working clamp thats supposedly good for 200 lbs. It got the bushing a little more than halfway, but still not in the right spot. This is getting frustrating, the weather was really nice today and I wanted to drive the car. Now I won't be able to even work on it until Sat. night. Considering blowing off Easter to work on it now too :shock:
            • m42technic
              • 1056
              Oh man... I put mine on at school yesterday at school. Thank god for special tools! :D
              James Peacock
              WWFSMD?
              • DaN
                • 1265
                Oh my god that was a bitch, and I had it on a lift.
                I just did it with my hand, and lots of lube, :oops: haha.
                I was super sweaty and pissed off, but I got her done.
                • franz
                  • 631
                  I did offset M3 on my car by hand, yes it was a super bitch. One of the few times I thought "good thing I'm 250lb"!
                  • DaN
                    • 1265
                    i'm only 160 lbs!
                    • mdv
                      • 61
                      Originally posted by DaN
                      i'm only 160 lbs!
                      I'm even less :shock:
                      • Jordan
                        • 12916
                        i'm only 160 lbs!
                        Haha ha
                        Little girlie men.
                        https://mtechniqueabs.com/
                        • rwh11385
                          lance_entities
                          • 18403
                          Damn, my sis is almost that heavy......
                          Like I said in the "what do you look like thread".....some on you guys need to learn how to eat. I'm skinny @ 185lbs.
                          I just did it with my hand, and lots of lube, haha.
                          :? We don't need to know about all the work you do with you hands.
                          • e30evolution
                            West Werks
                            • 1888
                            bolt the bushing to the car, and then use a heat gun to warm up the bushing, and then use some hand soap as a lubrican... then just slide the control arm in
                            http://www.westwerksauto.com
                            • Rosica
                              • Jan 2004
                              • 240
                              Re: Control Arm Bushing Install - Help!!!!
                              Dish soap and HOT water, hot being the key, let the bushing and bracket soak in the hot soapy water for a few minutes.
                              07 335xi Sport
                              00 S2k
                              01 A4 1.8t-Sold
                              88 M3-Sold
                              91 325iC-Totaled
                              89 325iS - Sold
                              87 325-Totaled
