M3 Control Arm Bushings...
  • Brew
    • 3060
    I searched...
    What exactly do they do for the geometry of the suspension?
    And how do they affect handling and stability?
    Thanks in advance.
    '91 318is
  • Charlie
    kid tested, administrator approved
    • 6686
    They offset the control arm, giving you a little more caster. Helps high speed stability and makes turn in feel a little better on higher speed corners, imo.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • Brew
      • 3060
      Cool.
      I've noticed that with the wider, 225 es100s my car feels a little "squirrelly" at higher speeds. I know that the control arms and bushings were replaced about 15k miles ago by the PO, so I think they should still be good. There may be some other bushings out front that are worn out, though.
      How do the offset bushings affect tire clearance?
      '91 318is
        • 34839
        they move the wheel forward a small amount. unless you are already close to rubbing the front of your fender liner, they don't really affect tire clearance any noticeable amount.
        • Brew
          • 3060
          Alright, I think I'll be OK clearance-wise, as the 225/50-15 are actually a tad bit undersized in overall diameter.
          '91 318is
          • rwh11385
            lance_entities
            • 18403
            This is true. Only time it'd really matter if it you were me--cheap and deseperate--and ran 205/60-15 would the wheel coming forward come into play to make a problem.
