Cylinder Head Rebuild Problem?
  • modifiede30
    • 1208
    I'm getting ready to rebuild the top end of my head and noticed the new rocker shafts slide all the way into the head without any force. This seems a bit odd given how difficult it was to get them out. Has anyone else experienced this problem? I also noticed that they are not permanently sealed, but rather have a hex bolt in each end. All the part numbers looked the same when I purchased them. Anyone have any info?
    Driving is the only way to go faster....
  • rs4pro3
    • 5808
    You've got the cam and all that in? I do remember the shafts on the 528e sliding in a little easier then they did out but it still wasn't just a push in job I had to do a little taping.
    85 325e 2.7 ITB'd stroker
    • modifiede30
      • 1208
      Everything is in except the shafts and rocker arms. No tapping was needed at all, just slid right in. The old ones need to be tapped, but not the new ones. Seems a bit odd to me.
      • Jordan
        • 12912
        did you slide the rocker shafts back in with or without the rockers? My brand new rocker shafts slid in and out easily enough. I don't think that is at all unusual.
        https://mtechniqueabs.com/
        • modifiede30
          • 1208
          Didn't put the rocker arms on, just wanted to see what the shafts fit like. Guess it'll be okay if that's no unusual.
          • modifiede30
            • 1208
            With the rocker arms, everything is tight so I don't think there will be any problems. However, I'm now finding that the eccentrics may be too small. Anyone ever used standard eccentrics with a regrind?
