Ok, what the hell is wrong with my car?
  • kowalski
    • Jan 2005
    • 1791
    #31
    check your wires, i had the same problem. from vibrations the wires cracked and would stop sending signals for a second, car would stall and then run just fine. Just wiggle all the wires around with the car running and see if it cuts.
      • 37829
      #32
      Originally posted by AdamF 88iS
      Does teh car have OBC?
      Yes although nothing on it is working since the motor swap. Apparently there is some shit I need to run to the glove box for that.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Axxe
        • Aug 2004
        • 3355
        #33
        Dude, I have the EXACT same problem on my M20 swapped 318iS. It's fucking annoying!! Been trying to track it down, but I want to replace my cap and rotor first, been 60k kms since I have done them and they are looking a bit worn.
        Keep it slideways!!
          • 37829
          #34
          I'm almost ready to swap out the whole wiring harness and see if that solves it.
          Grover Beach, CA
          www.BimmerHeads.com
          • crazynoll
            • Feb 2007
            • 54
            #35
            not an expert or anything but you dont have platinum plugs in right?
            <img src=http://www.r3vlimited.com/board/image.php?u=14143&dateline=1175417424&type=profile >
              • 37829
              #36
              Bosch Super plugs are all I use.
              Grover Beach, CA
              www.BimmerHeads.com
              • Mike325
                • Mar 2006
                • 3685
                #37
                Try changing your plugs first like I had mentioned eairlier.
                Originally posted by Kershaw
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  #38
                  Have you checked the injector harness pins for corrosion?
                  Will
                  RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                  Welcome e30 (brilliantrot '90 325is) 12/23/06
                  DaveCN = Old Man
                  My signature picture was taken by ME! Not by anyone else!
                  If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                    • 37829
                    #39
                    To top off this fucking situation... My keys have been lost since Tuesday!!!
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • RobertK
                      Kicked cancer's ASS.
                      • Jun 2005
                      • 5864
                      #40
                      I seriously doubt plugs are the cause of this problem.
                      Once you find your keys try tugging or wiggling on the ignition once you start it up to see if there is a loose contact there.
                      EDIT: Have you thoroughly checked your battery connectors?
                      • Mike325
                        • Mar 2006
                        • 3685
                        #41
                        It is worth a shot tho. Just suggesting because this fix the same problem on another car of mine.
                        • Rocla
                          • 922
                          #42
                          OBC should work if RPM and mpg gauges work.
                          Current:
                          BMW 320i 2d 2.0 m20 -88
                          BMW 325i Cabriolet 2.5 m50 -88
                          BMW 316i touring 1.6 m40 -90
                          BMW 320i 4d 2,2 m54 -01
                          • ACHTUNG
                            • May 2005
                            • 2397
                            #43
                            All grounds are attached.
                            I had very similar symptoms and it turned out that my grounds needed to be cleaned up and tightened.
                            1989 US E30 Cammed S52
                            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                              • 37829
                              #44
                              My tach is not hooked up.
                              Grover Beach, CA
                              www.BimmerHeads.com
                                • 37829
                                #45
                                The motor has been in the car less than 2 months, all of the grounds are fine.
                                Grover Beach, CA
                                www.BimmerHeads.com
