couple probs, as usual
  • NC325iC
    • Mar 2004
    • 6565
    1)cruise control stopped working donno why any idea what to check, it stopped after i got the tranny back in and the car back together
    2)pass window doesnt work, and currently the door is perma locked, itll unlock when it gets warm enough.
    the lock problem comes and goes, i need to take it out and clean it up, back to the problem at hand though
    last time the door was perma locked the window stopped working for a while,then when it unlocked the window started working again, any plans
    3)from time to time my brake check light comes on while driving
    past that the car is runnin better than ever
  • lordofthewaters
    • Oct 2005
    • 714
    Did you do a 5 speed swap or something? Sorry not keeping up. There is a cruise cable to the throttle that must be adjusted (as I'm sure you know) did you check that?
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • Mike325
      • Mar 2006
      • 3685
      I bet the window is frozen closed like your door is. Don't try to put your window down as that can burn out your motor.
      Originally posted by Kershaw
      • winstontj
        • Mar 2007
        • 500
        You probably have a short. Check the wires to see if they are frayed or possibly check your brakes - perhaps the light is legit??
        • NC325iC
          • Mar 2004
          • 6565
          the window motor doesnt run i dont think, cause i cant hear it when i push the button
          i just did a clutch change not a swap or anything
            • 34844
            nope, it's easier than that. his brake light switch is going out. it's by the brake pedal, and costs somewhere between $5 and $10. easy to replace too.
            • NC325iC
              • Mar 2004
              • 6565
              i thought that might be it, i almost replaced it a while ago but decided not to
              • bimmerboy570
                • Mar 2007
                • 63
                when u do it make shure its adjusted or you will have some issues
