Do the 318i e30s with a battery under the front hood have a fusable link ?
fusable link question
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Tags: None
Jean, not sure on this question. My first guess would be no. Are you not getting any spark? The fuseable link would only cause a no spark.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
Not getting any voltage to the ignition coil, unless I am not measuring it right...Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Figured it out, I was mearing it across the +/- terminals.
The problem was a broken distributor rotor, looks like my battery slides over and hits the damn thing..Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
trent
yep, going to relocate it out to the trunk.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
