trying to get the tach to work in my stroker...
  • JAM
    • Feb 2007
    • 524
    i found the insterment cluster harness in this maze of wiring, and going off of what it says on strictlyeta.net, i have to splice 2 wires from the instrument cluster harness to the engine harness. it says to splice -
    - black wire from instrument cluster harness to black wire on engine harness (runs to pin #6)
    - yellow/white wire from instrument cluster harness to white/black wire on engine harness (runs to pin #32).
    the problem is is i cant find a plain black or a black/white wire anywhere on the engine harness (to the ecu). can anyone help me? try to figure out which wire goes to pin #6 and pin #32?
    thanks
    Originally posted by Mr Watsonsilver
    driving boards?
  • winstontj
    • Mar 2007
    • 500
    Tach runs off the coil. Maybe either look at the coil and check that color... OR jump direct from the coil to the tach just to get a signal and make sure it's working... Once you get it working then look at the colors wired to the coil and look at the harness for one of those colors...
    Sorry I can't be of any more help
    • JAM
      • Feb 2007
      • 524
      um... putting my flame suit on....
      where is the coil located? what does it look like?
      sorry, im a n00b
      edit - nvmd i found it im retarded lol
      driving boards?
      • JAM
        • Feb 2007
        • 524
        meh... coil didnt really give me any clues...
        after looking at my bentley i realized in every wiring diagram in the book there is a diffrent diagram for pre/post 88. the car on strictly eta was an 86... doh.
        can anyone point me in the right direction as to what wires in the big harness to the ecu does what? wouldnt there be a write up somewhere or something?
        driving boards?
          • 37833
          Why are you doing wiring for a stroker? The stock harness will work just fine.
          Grover Beach, California
          BimmerHeads.com
          • JAM
            • Feb 2007
            • 524
            my tach doesn't work, i figured this is my problem seeing how both wires from the cluster are cut and not connected to anything
            driving boards?
              Nope, the tach and motometer signals are from the DME. I suppose you could say that they are indirectly derived from the coil... But they really are derived from the timing reference sensor.
              • JAM
                • Feb 2007
                • 524
                so... anyone know what color wires are for the engine speed output and fuel consumption output on a 1990 325is?
                cmon...
                driving boards?
                • JAM
                  • Feb 2007
                  • 524
                  bueler?
                  driving boards?
                  • JAM
                    • Feb 2007
                    • 524
                    driving boards?
                    • JAM
                      • Feb 2007
                      • 524
                      nothing?
                      cmon, there has to be someone with a badass shop manual on here...
                      driving boards?
                      • backtrail69
                        • Jul 2005
                        • 4471
                        Sounds like maybe your Si board/cluster is bad. You didn't need to change from eta to i wiring in your swap...
                        :: PNW Crew ::
                        '87 325 4dr, '74 2002
