Weird Clutch
  • 88e30is
    • Feb 2007
    • 690
    Weird Clutch
    I just got my engine in my 88 325i and I put the clutch cylinder on the transmission where it goes and I got in my car, pushed the clutch and it was really really really stiff but moved. Once it got to the floor it stayed there...I can pull it back up and push it down but its still really stiff....does this mean I need to bleed it? What kind of fluid should I use?
  • MrK
    • Jan 2006
    • 709
    Sounds like your clutch slave/master combo need to be replaced. That is assuming that you've bled the system and it still behaves this way.
    This is your M20 on steroids:
    • Mike325
      • Mar 2006
      • 3685
      Are you sure that the slave pushrod is in the little indent that it sits into? How hard/easy is it to pull the clutch pedal off the floor?
      Originally posted by Kershaw
      • NC325iC
        • Mar 2004
        • 6565
        that happens to me just about every time i bleed my clutch, pump it back and forth a bit and see if that helps out, if you can do it with the car on that might be better
        • backtrail69
          • Jul 2005
          • 4471
          I was having troubles bleeding my clutch, so I just bought a vacuum bleeder at schucks today. Worked great. Sucked all the air out of the system.
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • 88e30is
            • Feb 2007
            • 690
            Bleeding tomorrow. I will let you all know. Thanks.
