t-belt 89 325i
  • viali8
    • Nov 2005
    • 673
    t-belt 89 325i
    when replacing the timing belt is it necessary to replace the tensioner spring. Can the spring be used over and over again. thanks Matt
  • JPL
    • May 2005
    • 774
    i re-used mine
    Originally posted by Hawt drift chick
    Yeah, i'm a good dude i swear, i just like to be balls to the wall.
    • viali8
      • Nov 2005
      • 673
      anyone else
        • 37833
        You can reuse it, no big deal.
        Grover Beach, California
        BimmerHeads.com
        • viali8
          • Nov 2005
          • 673
          thanks guys. gonna go try to finish it right now.
          • PeaveyBassist
            • Sep 2004
            • 3511
            Reuse it.
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • VAPORBLADE
              • Sep 2006
              • 1771
              I went new - but that is how I am rollin' with my car.
              '89 "is" = M technic II build mode.
              • viali8
                • Nov 2005
                • 673
                Just finished putting the new belt on. I loosenedt he upper tensioner bolt to put tension on the belt. I am supposed to tighten that nut up again or leave it loose?
                When i cranked the motor 720 degrees it lined up where it was supposed to. but i cranked some more by hand and at certain times there is some slack in the belt. is that normal?
                • redhatpat
                  • Aug 2005
                  • 656
                  There shouldn't be any slack in the belt, thats what the tensioner stops from happening. Turn the engine over twice (or more), confirm the timing marks line up, and then tighten down the tensioner bolt to lock it in place. There shouldn't be any slack in the belt.
                  • Nick325is
                    • 1409
                    I didn't even put the spring back in when I did the T-belt last time. Once its tightened down you really don't need it til the next time.
                    -Nick
                    • viali8
                      • Nov 2005
                      • 673
                      thanks guys
                      • viali8
                        • Nov 2005
                        • 673
                        How do you get the power steering pump to move inward so i can slip the belt over the pulley. i know there is a toothed bolt but do i have to loosen any other bolts to get the pump to move. or do i just crank on the toothed bolt. thanks Matt
