Oxygen Sensor Testing?
  • GreekDriver
    • 100
    How do I test to see if my oxygen sensor is dead? I don't have the complete records of the car, so I don't know if it's been replaced the last 40,000 miles.
    Thanks!
  • m42technic
    • 1056
    Voltmeter?
    James Peacock
    WWFSMD?
    • kencopperwheat
      King of Kegstands
      • 14396
      I'd say just replace it to be safe.
      Originally posted by Gruelius
      • Jand3rson
        • 37587
        Yeah, it's not hard, and they aren't TOO terribly expensive, like $90 or something like that. At least then, you will know it's brand-new.
          • 34827
          you can get them for $75 plus shipping on ebay
          • OOMPH!
            • 3487
            does your check engine light come on when your car is at a stop? and then goes off when you start moving?
            • Erick
              Official R3V Drifter
              • 11169
              www.eap4parts.com where I plan on getting my front wheel bearing and my o2 sensor sometime this month.
              ..::Support FullOpp::..
              FullOpp Stickers for sale!
              Feedback Thread
              • e30evolution
                West Werks
                • 1888
                you cant really check it with a volt meter properly, because the voltage osilates between 0 and 1v, you can check to see if it is creating a voltage, but you wont be able to tell if you have a lazy sensor. you need to hook it up to a scope.
                http://www.westwerksauto.com
                • m42technic
                  • 1056
                  Depends on the refresh rate of your voltmeter...
                  James Peacock
                  WWFSMD?
                  • Jand3rson
                    • 37587
                    My o2 sensor was dead, and my check engine light was on almost all the time. I finally just pulled the damn bulb for it out of the cluster. Useless fucking check engine light.
                    • nateb
                      • Apr 2004
                      • 54
                      If your check engine light is not on can you assume your oxygen sensor is operating properly?
                      • Jand3rson
                        • 37587
                        I would assume so. 99.9% of the time, that's the reason the check engine light comes on in E30's.
                        • OOMPH!
                          • 3487
                          I say yes, also if your exhaust has a weird smell (carbon dioxide) then your O2 is probably bad.
                          • nateb
                            • Apr 2004
                            • 54
                            When referring to the check engine light, is it the same as the flashing CHECK light that directs you to the overhead check panel?
                            The previous owner of my car took out the SI lights so if the check engine light is part of that then I won't see it until i fix that.
                            Thanks
                            -nate-
                            • m42technic
                              • 1056
                              You cant smell carbon dioxide. You can however smell hydrocarbons. :P ;)
                              James Peacock
                              WWFSMD?
