m20 grounding points.
  • e30 gangsta
    • 3877
    So i know off these 2. The one that is connected to the hood and the one that is on the drivers side to the left off the oil pan that is connected to the chassi. Is there any other ground points in the motor that i should know about? Becuase im going to replace all the grounds.
  • backtrail69
    • Jul 2005
    • 4471
    The Main ground on the shock tower on the Pass. Side.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • e30 gangsta
      • 3877
      got that one any others?
      • e30m20beast
        • Aug 2009
        • 176
        damn man I have the same problem, on my car when I bought it, it had one ramdom cable from the chassis to the transmission (it was cut)but I am trying to find out if that one is original or not
        • SpecM
          • Oct 2005
          • 4531
          that wouldn't have been origional
          1989 cirrisblau-metallic 325i
            • 34844
            there is the ground to the oil pan/subframe, passenger shock tower, and maybe the starter?
            you don't probably need the hood ground, I think that was a little overkill on the part of bmw. my hood isn't made of metal, how the hell do you ground that?
            • txtorquemade
              • 1758
              CF hood nando?
              Dont the grounds "ground" different circuits making them all necessary?
              sigpic 1987 325is
                • 34844
                for the most part, yes, but what circuit is there in the hood? it just seems odd, especially since the hood is bolted to the body anyway.
                • guibo09
                  • Dec 2008
                  • 834
                  some e30 hoods, like mine, have heated windshield nozzles, so there is some circuitry there.
                  however, the official bmw reason for the hood ground strap is RF interference for the radio as seen in the ETK.
                  90 E30 325i
                    • 34844
                    yeah, that's pretty much what I thought, but it's still bolted to the car. can you say overkill? :p
                    • guibo09
                      • Dec 2008
                      • 834
                      yeah pretty much overkill. i guess there is paint inbetween the bolted parts which reduce the conductivity, but yeah, overkill for the most part.
                      90 E30 325i
                      • txtorquemade
                        • 1758
                        Has anyone ever heard (nando??).. of grounding the stereo amp to a nail and dropping the nail down between the dash and firewall? This is supposed to prevent 60cycle interference from "humming" in the speakers.
                        Does that work?? Any ideas??
                        sigpic 1987 325is
                          • 34844
                          you would want to ask luke (stereoinstaller) about that. I don't know shit about stereos. I have a $100 blaupunkt MP3/CD player and the stock speakers. most of the time it's turned off. :p
                          • e30m20beast
                            • Aug 2009
                            • 176
                            is there any page or something like that that tells you all the grounding points of the car? I am having big problems with grounding all around the car ( windows won't go down, radio won't work and a bunch of other things.
                            • 808BMW
                              • 2910
                              And the nail is dangling behind your dash? Sounds like your just introducing a "nail swinging behind my dash" hum.
                              I'd ground the stereo equipment better, this nail "trick" is one of the best things I've heard in the stereo world :P
