4 door vs 2 door weight?
  • Kruzen
    • Mar 2004
    • 5603
    on a 89-91 325i
    just curious what the weight difference is. and how much it would effect performanc.e
    Who doesn't love a little BBQ?
    Griot's Garage at a Deep Discount
  • Sean
    • 5793
    Even if there is a difference, it's probably so marginal that it would never be noticed.
    It's probably a 3-4 lb difference, if anything at all.
    - Sean Hayes
      • 34844
      well, if you count the B-pillar, door and window hardware, it's probably about 50lbs or less. not really a big deal. plus, 4 doors tend to be stiffer and having a B pillar right next to your head is a good thing :)
      • christophbmw
        • Mar 2004
        • 363
        um just to let you know its about a 200 pound difference and four door cars are alot less stiff. ill let you know the exact weight difference when i get home and look it up.
        '91 318is
        • C ///M
          • 1040
          You're a dumbass. If you have no fucking clue what you're talking about then don't post.
          Back on topic.
          Anyway, Depending on which e30, it ranges from as low as a 30ish lb difference up to a 60lb difference, and yes, e30 as well as e36 sedan's have a more rigid chassis.
          If you want to compare two of the exact same chassis, ie. '89 325i 4 door vs. '89 325i 2 door, both cars manual transmission, and neither of them an ix, than expect the 4 door to be about 40lbs heavier. Fred Kim did an AWESOME job of getting all the specs for U.S. e30's, all model year, etc.. Check out his website under Technical Information and Specifications page two. He's got every single e30's weight, including all 2 and 4 door cars, automatic and manual trans difference, and rear wheel and four wheel drive difference. :up:
          P.S. This is a reminder for members, if you aren't sure about information, don't post it like it's a fact. Misinformation runs rampant because too many people who think they know what they are talking about post entirely too much bullshit.
          332iS R.I.P.
          • Kruzen
            • Mar 2004
            • 5603
            ah.. so if i got a 4 door instead of 2 door.. my performance really wouldn't be that hindered at all.. and with the stiffer chassis, might even improve cornering and what not?
            • kencopperwheat
              King of Kegstands
              • 14396
              Correct.
              I'm pretty partial to the aesthetics of the 2-door though. The 4-door doesn't really do it for me.
              Originally posted by Gruelius
              • Kruzen
                • Mar 2004
                • 5603
                Correct.
                yar.. two door is hawt.
                but this is just another thing i can allow to be lenient on if the right sale comes aloong.
                • natorious
                  • 672
                  4-door is cheaper on the insurance too... =)
                  i like my 4-door it comes in handy when i need to drive people around..
                  • gsbadbmr
                    • 129
                    4 Doors OWN.....................................
                    -gsbadbmr
                    • Tangent
                      • Mar 2004
                      • 476
                      A 4 door being stiffer than a 2 door is new to me. I always figured that cutting an extra pair of holes in the side of a car to put doors there would be worse for structural integrity... :?
                      • e30Matt
                        • 5077
                        Now that I've owned a 2dr for a while, every time I get in a 4dr car I bang my ass on the B pillar. I love coupes. :) So much easier to get in and out of, bigger windows to see out of, not to mention less room for 2-3 backseat drivers we all don't need.
                        • sovann
                          • Jan 2004
                          • 292
                          What about weight distribution? Anyone have any 2dr vs. 4dr info? I assume 4drs would have more weight over the back than 2drs but it would be interesting if someone could quantify it.
                          • bimmerphile
                            • 3495
                            Funny, that's exactly why I don't want a 4-door :P
                            • OreoGaborio
                              • 1285
                              Exactly what C///M said
                              the 4-door is more rigid because there's a large strong B pillar that needs to hold up a door. the weight difference isn't much as you would think, because the door on the 2-door is larger & heavier than the ones found on a 4-door, narrowing the expected weight difference a little
                              sure the 4-door has "an extra pair of holes in the side" like Tangent said, but like i said above, because the doors need something to mount to, a B-pillar was put in place that not only holds the doors up but contributes to structural rigidity
                              also, the doors are not much different than the side panneling thats behind the large door of a 2-door... so there's not much extra weight there, either... and the glass?... well, a 2-door has glass behind the doors, too.... just no motor & track to move it up & down.
                              and the handle mechanism doesn't weigh much either
                              basically at first i can see how alot of guys would think that a 4-door would be significanly heavier than a 2-door... but the more you think about it, the more common sense will prevail & tell you that yes, there is definitely a weight difference, just not quite as much as you would think
                              As for weight distribution, i'm gonna venture a guess & say that the difference would be very negligible, but the 4-door would probably have a slight edge if there was any difference at all
                              -Pete
                              LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
                              Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
                              The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)
