Is it very difficult to replace the oil cooler lines? Scale of 1 - 10? Something the mechanically challenged should attempt themselves or have a shop do it?
If you are questioning this job just have a shop do it, it will make your life less stressful. For me it might be easy, but for you it might be very difficult, it is hard to judge.
Good enough for me. Hesitation + no tools = shop does the work... that is unless someone local has the right skills/wrenches and wants to make a $100 ;)
If you want to come up to La Crescenta I can do it. I could use a little extra cash for bfest.
