Vibration while free revving - very fast vibe
  • dinanm3atl
    • Feb 2007
    • 7305
    Like a shudder. Just put in new tranny mounts that are very stiff. I could not feel this before. The car has a vibe/shudder that is very fast when you blip the throttle at while not moving. It goes away around 2500-3000 rpm. Anyone else every experience this?
    • 34844
    are they urethane?
    if so, that's your problem. I just put in a urethane filled rubber tranny mount in my car, I can hear a little more of the tranny but it's not too bad. solid urethane would pretty much suck though..
    • dinanm3atl
      • Feb 2007
      • 7305
      Originally posted by nando
      are they urethane?
      No it is rubber mount but comparing to a brand new OEM BMW dealer bought mount it is a food 2x or 3x harder rubber.
      • PeaveyBassist
        • Sep 2004
        • 3511
        Probably just the trans mounts. I have straight through bolt mounts for the engine/trans and a delrin diff mount. My car vibrates a little hahahaha.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • Dibo718
          • Oct 2006
          • 137
          Did you touch the drive shaft at all? If you unbolted it and then attached it again, maybe it became unbalanced, my brother did a 5 speed swap on his e46 and he gets the same vibrations due to his driveshaft being unbalanced. Just a thought.
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            Maybe you are running too rich.
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • PeaveyBassist
              • Sep 2004
              • 3511
              Doesn't make any sense. How would unbolting it from the trans and bolting it back up again make any difference in balance? And you dont have to unbolt it to change the trans mounts anyways.
              Will
              DaveCN = Old Man
              • Garageaholic
                • Dec 2005
                • 5204
                Are you running on all 6 cylinders? I know it sounds trivial and you may have already checked it, but maybe one of your plug wires are loose and needs to be pushed back on the plug...
                Is the car running like shit? or just vibrating?
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • dinanm3atl
                  • Feb 2007
                  • 7305
                  It was out and guibo and CSB was replaced 3 weeks ago. I don't think this is a problem. It was not disconnected to replace the trans mounts.
                  U joints and everything felt great
                  This is interesting and could definitely be something... Another problem I am having someone was telling me to check my FPR because he had a similar problem and was running rich at idle
                  Um it runs good. Really good except if you free rev like that...
