Hummmmmmmmmmmmmmmmmmmmmmm
  • JPL
    • May 2005
    • 774
    in the last couple months I replaced my tranny and diff fluid with Redline. I notice a hum generally at all speeds but especially between 60-70 mph and almost as loud above that. should i be worried?
    are my bearings shot? they were replaced at 88,000 miles and now the car has 106,000 miles. i also get a little vibration at high speeds from the wheels. could that be my rotors being a tad bit warped?
    i might just be paranoid b/c every little sound i hear from my car i think about where it might be coming from for awhile.
    a little help would be much appreciated.
    thanks,
    jake
    Originally posted by Hawt drift chick
    Yeah, i'm a good dude i swear, i just like to be balls to the wall.
  • browntown
    • Jun 2004
    • 3524
    ever had your car aligned? some tires will hum. bearings shouldn't go that quick. can you identify where the hum is coming from?
    • JPL
      • May 2005
      • 774
      yea i've had my car aligned a couple times. I have Kumho Ecsta MX tires. its a general hum. but if i had to say where it was mostly coming from i'd say the rear of the car.
      could it be that my tires just need to be balanced?
      • JGood
        • Jan 2004
        • 7959
        Did you put a limited slip additive in the diff? I did that and my diff grenaded 2 days later. It went into full lock and I was chirping tires while turning around in parking lots. I'm sure if I would have went on the highway before that happened, it would have been making a humming noise of sorts.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • JPL
          • May 2005
          • 774
          no additive either
          • Jparkr
            HR Admin
            • Jan 2006
            • 3494
            its hard without hearing your car but i would say diff whine if it is comeing from the rear... how was the diff fluid when you drained it?
            1987 PRO-3 car /1990 325is (2.7i Concours)
            • JPL
              • May 2005
              • 774
              nothing peculiar (hope i spelled that right) just old and smelly. i'm gonna chalk this up to me being paranoid unless someone has a better idea or my diff locks up.
              • jrobie79
                • Mar 2006
                • 2526
                i got the same problem, it sounds like its comign from the rear, and i can only hear it when i have my foot on the accelerator, if i take it off on the highway it goes away, so i dunno, but if its the same as mine, i drove to florida and back plus the last few months, about 6 thousand miles while it was making the noise and nothings broken yet so i dunno id say its all good
                1991 318i ---- 308K - retired
