did a burnout up a freeway offramp...
  • ptownTSI
    • Jun 2005
    • 1265
    now it is making a ticking sound and feels sluggish with not much power.
    I bounced off the limiter for no more than 2 seconds before shifting. could i have burned a hole in a piston? broke a rocker? it sounds like the worlds loudest M20 injector. but the whole engine, and it is rough on take off and really ticky as i get up to speed.
    very smooth idle.
    • 37833
    I broke a rocker getting on to the freeway. It would be obvious though, my car was running on 5.
    Grover Beach, California
    BimmerHeads.com
    • ptownTSI
      • Jun 2005
      • 1265
      i bet its the rocker. will pull valve cover tomorrow and inspect. they seem to get fragile as these cars age no? i've never broken one in any other car before.
      • ptownTSI
        • Jun 2005
        • 1265
        broke the #1 rocker, there was already a break on the rocker shaft guide of that cylinder and i'm guessing it contributed to it. time to get a junkyard head and rebuild 'er.
        • Low Level E30
          • 1646
          What happens to the head when you break a rocker? Is it as simple as just swapping in a new one... ? I'm assuming it's not...
          • fretburnr
            • Jan 2005
            • 1496
            when a rocker breaks, the valvespring forces the valve closed... so it won't ge t struck by a piston. but i'm sure having a loose bit of rocker flying around on your head can score the cam or other parts. shouldn't hurt the head itself.
            Jay
            • Low Level E30
              • 1646
              How easy are rockers to replace?
              • backtrail69
                • Jul 2005
                • 4471
                Depending on the location usually it entales pulling the head off the engine.
                :: PNW Crew ::
                '87 325 4dr, '74 2002
                • Mr Deagle
                  • 1121
                  If its the number 1 rocker, you will need to pull the head
                  you can only change rockers 456 while head is still in the car
                    • 37833
                    Mine was on the back of the motor, I got lucky. Got a new one and that's it, no harm done.
                    BimmerHeads.com
                    • asubimmer
                      • 6482
                      your lucky it was only one rocker arm, but stinks none the less
                      • ptownTSI
                        • Jun 2005
                        • 1265
                        do these things break often when you hit the limiter or something? whats the point of having a limiter that high if shit breaks.
                        • AlarmedBread
                          • Sep 2006
                          • 1510
                          Move you limiter down to 6k and bump away.
                          It is not designed to be bumped off all day, merely as a safety precaution.
                          • backtrail69
                            • Jul 2005
                            • 4471
                            I have never broken one with a turbo charged motor, my chipped eta or in my m10....but I avoid bouncing anything off the limiter.
                            :: PNW Crew ::
                            • Jean
                              • 18228
                              get some aftermarket rockers that won't break at 6500-7k rpm.
