did a burnout up a freeway offramp...
    rockers. lol!
      Originally posted by Jean View Post
      get some aftermarket rockers that won't break at 6500-7k rpm.
      Or find someone who can properly weld aluminum to reinforce stock ones. :) I've seen it done on an M30 and I'm having mine reinforced just in case. After seeing the abuse that M30 goes through (at much higher RPMs) I'm set on having that done for my M20.
      - Erick
      ..::Support FullOpp::..
      FullOpp Stickers for sale!
      Feedback Thread
        i'll just make sure not to bounce off the limiter at all costs!
          lol i bounce my eta all the time you get better shifts if you let it hit cause the revs drop faster
          '89 Alpine S52 with goodies
            Did you drive a Honda before you got your BMW?
              rockers break due to worn valve springs. the valves "float" ad that is what causes them to break( the rocker is moving faster than the valve. put new springs in it and your golden. the stock rockers can handle the revs no problem
                hhmmm, sounds like a statement i would make, but i am not THAT stupid.
                and no it doesnt, hitting the r3vlimiter probably slows you down, especially if you are trying to pay attention to traffic and you dont realize how close you are.
                if you want better shifts, get a clutch stop, a short shifter, or just better yourself. letting it hit off of the r3vlimiter doesnt have any positive benefits in that scenario.
                  i still need to replace my #6 rockers. but yeah, i wish i had the spare dough for some MM rockers, or even the reinforced ones that IE is selling.
                  Claus Luthe is my hero.
                    I hope you're kidding.
                    Bryan - 1989 325i S50 swapped /1990 Audi Coupe Quattro
                      Sounds like a joke to me... come on guys, it's an eta... lol
                        At least 1 other person on here knows about floating/ rocker breaking
                          Yes Mr. Deagle, because out of all of the BMW engines in the world that have suffered valve float and broken rocker arms, somehow nobody has figured it out. Thank God we have you
                            dude sounds like the same exact thing that I done to my M20. Exactly the same type of conditions, ei reving hard up a highway merger ramp to redline on first gear. THe engine let go whiel shifting from 1st to 2nd.
                            In my case all the rockers were fine... the noise is coming from the bottom end. I figure I have either a busted rod or spun bearing on #5 or #6.
                            I just got putting in a replacement M20 so I will tear the broken engine to find out the culprit.
                            - 0.05s and 0.1s FTW!!!
