Rear Pop Out Window "weather seal"
  • dinanm3atl
    • Feb 2007
    • 7305
    On the rear pop out windows on an 89 e30
    There is an "inner" seal I guess and an "outer" seal... Well my driver side has both of these...
    The passenger side only has the inside and I think that is where my wind noise is coming from.
    How do I replace this?
  • Beej '86 325es
    • 2639
    I'm reviving this ancient thread.
    I've been repainting my trim and replacing the seals. I replaced the main weather seal:
    But when the window is closed, you can still see a gap between the inner and outer trim pieces. It looks like there should be a rubber seal in between like there is on the top of the door.
    I ordered these two seals also. The ones on the right get inserted into the bottom trim of the pop-out. The one on the left supposedly goes around the top and back, but I don't see how this little thing will help, no matter where you attach it, will help anything at all.
    Here's a link to the Parts Catalog:
    Does anyone have a closeup photo of their window seals?
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • Chinampa
      • Jul 2013
      • 247
      I'm interested as well...im putting pop out rears in my '90
      - 90 325is
      • rzerob
        • Jun 2013
        • 2315
        I just put pop outs in my 91, I did a write up for it. Really easy if you have all the parts. I am interested to see what you do OP, Mine work fine now but I am sure I will need to update parts later.
        • jeffnhiscars
          • Jun 2011
          • 6010
          Old thread rebump
          Can you replace the main seal without removing the inner panel and how do you get to the hinges to get the window off ?
          Note I've read the "conversion" threads but already have the pop outs and am just wanting to replace the seals.
          Alice the Time Capsule
