Replacing rear window
  • Super Eta
    • 1884
    What are some good tips on replacing a rear window and doing it succesfully?
    • 37833
    Well, I actually just replaced mine because someone though it would be fun to throw a rock at it while I was driving... You'd be amazed how many pieces your back window can turn in to, lol.
    Anyway, me and a friend did it in like 30-45 minutes. We took out the rubber gasket that goes around the window and cleaned the broken glass out of it. Also, had to vacuum up all the broken glass which was all over the car, that actually took a while. Anyway after we had things cleaned up, we put the gasket back in, then sild one side of the window in, and got the rest of the window in with the help of a puddy knife.
    Sorry if that's not too good of an explination but, I tried. :)
    Grover Beach, California
    BimmerHeads.com
    • Spaz
      Crazy Canuck
      • 2276
      since jordan has removed every part from his e30 i'm pretty sure he knows....pm him maybe?
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • rs4pro3
        • 5808
        I had to replaced the rear window on my 84 318i when I got it, I too just slid in one side of the window and used a small skiny oblject to slide around the window pulling the gasket over the rest of the window. The hardest part is probally getting the lock strip back in.
        85 325e 2.7 ITB'd stroker
        • esam
          • Apr 2004
          • 3
          when replacing the front or rear glass and lock strip, some silicon spray lube does wonders to help everything slide in.
