Buzzing noise...
  • Evan318is
    • Apr 2004
    • 3
    Buzzing noise...
    Ok guys, here's the deal. About 2 weeks ago I replaced my Fuel Pump ( in tank ). About two days ago I started to hear a buzzing or a humming noise from about the same place as where the fuel pump is located. I also hear it when I turn the key to the "Run" position, but it only humms for about a second. As soon as I start the car though and the entire time its running, I hear the humming noise. Do you think it could have anything to do with the fuel pump? Any other suggestions? Thanks in advance.
    Evan
  • Streetspec_iS
    • 1622
    some fuel pumos do buzz, yes. did you get an exact replacement. ive had my back seats out for about a week, and the buzz from the pump is actually quite loud.
    sigpicM42 Brigade ... Throwing craze in the 318
    • e30Matt
      • 5077
      A hum for a second or two is quite normal when you turn the key to run.
      • ///M42 sport
        • 3952
        mine new pump buzzed louder than normal for a while, then it went away.
        ________
        INFANT NEXIUM
        • spencers
          • Jan 2004
          • 1150
          my fuel pump still buzzes. grrr. it sucks being poor
          • Schneider325
            • May 2004
            • 3818
            I have a buzzing coming for right near the fuel filter. I dont think its the pump.. it sounds like its that part right after the filter...
            17 ABSORBER 1 06/1986 09/1987 16121178035 $53.85
            is that recommended to be replaced? I figure if that part can go bad and its buzzing.. it might be causing me some fuel economy and power
            • cobraken
              • Oct 2004
              • 674
              My fuel absorber also whines even after i replaced the external fuel pump and the absorber. I dont know what else to do to make the sound go away except possibly replace the intank pump.
              Randall Racing and Engineering
              Acworth, Georgia, 30101
              http://www.facebook.com/RandallRacingandEngineering
              • Schniddy
                • May 2004
                • 3818
                If it an't broke, don't fix it. Test the pump out, might be normal.
                  • 34844
                  delete the fuel absorber/damper if you have one. BMW stopped using them for a reason.
                  • Schniddy
                    • May 2004
                    • 3818
                    Looks like a case of over engineering then.
                    • cobraken
                      • Oct 2004
                      • 674
                      I can dig that. The thing is, if my in tank pump wasnt working how could i tell?
