Any Way to Quiet Input Shaft Bearing Noise
  • DJB
    • Oct 2005
    • 195
    The problem is the layshaft and unloaded gears (especially reverse) oscillating.
    A light flywheel makes the noise worse as there is more variation in input speed.
    Heavier transmission oil adds drag and cushions the gears better, reducing the noise.
    Shimming the layshaft and replacing the layshaft end bearings with tighter ones will eliminate the noise. At least until things loosen up again.
    • Axxe
      • Aug 2004
      • 3355
      I put in RP Synchromax into my really badly rattling getrag, didn't help much at all. My loopy idle doesn't help though.
      Keep it slideways!!
      • HST
        • Jan 2006
        • 757
        The trans he has uses ATF so there is not really a heaver oil that you can put into it. I guess you could try like 75w-90 but I don't know what it might do.
        Originally posted by KingB
        Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
        • RobertK
          Kicked cancer's ASS.
          • Jun 2005
          • 5864
          Actually, I think that Lucas ATF treatment might do the trick. It's kinda thick.
            • 34844
            I don't think it matters. my trans originally was filled with ATF, I drained that out a long time ago and filled it with redline.
