Can someone please show me a diagram or tell me the location of the fuel pump relay?
  • RyanZ06
    • Apr 2007
    • 226
    I have searched and searched. People keep talking about the fuel pump relay, but no one talks about the location of the unit. I am only getting 3V of power when i turn my key and try and start the car.
    Thanks
  • rs4pro3
    • 5808
    pop the hood, on the side of the driver's side strut tower is a black plastic cover next to the air flow meter and air filter. Pop the cover off and inside are three relays, fuel pump is typically the middle one.
    85 325e 2.7 ITB'd stroker
    • RyanZ06
      • Apr 2007
      • 226
      I have a m52 swap. I am using an OBD1 E36 m3 harness. Same 3 fuses?
      Thanks!
      • 87-325ic
        • Apr 2006
        • 1198
        eh, i thought mine was the furthest to the front.
        they are, Fuel, O2 heater, Main.
        maybe not in that particular order..
        do you have a bentley?
          On a 90 325i the fuel pump relay is the middle relay of the three mounted on the driver's fender well.
          Note that the relay is closed by the DME once it sees timing reference signals from the crank position sensor. So you won't see power to the pumps unles the engine is cranking over and the DME and timing reference sensor are operating. To test the pump you can jumper the contacts in the relay socket.
          • RyanZ06
            • Apr 2007
            • 226
            thank you guys, i'm going to continue to trouble shoot.
            Right now i ahve no fuel and no spark. I have a red lable ECU and full OBD1 conversion. any more input out be greatly appreciated.
            • RyanZ06
              • Apr 2007
              • 226
              It Runnnnnnnnns!!!!!!!!!!!!
