e34 tranny question.... pops outta 2nd
  • OreoGaborio
    • 1285
    and we don't THINK it's the synchros. here's the scenario:
    obviously from a stop, ya put it in 1st, let out the clutch, accelerate. Shift to second, feel it go in, let out the clutch & you can feel the shift linkage "shimmy" ever so slightly. stay on the gas & it stays in... let OFF the gas & POP... comes right out to neutral.
    it will also pop out if you're coasting in neutral, put it into 2nd and let out the clutch w/o getting on the gas again.
    i think he said something about hearing a "twang" from the shifter linkage area when it started doing it
    any thoughts? something wrong w/ the linkage hopfully?
    -Pete
    LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
    Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
    The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)
  • Nick325is
    • 1409
    My friend's mom's e34 525i does the exact same thing. Pops out of 2nd gear all the time. It seems to be a recurring problem on the e34s from what I have seen. Sorry I can't be of any help.
    Nick
    • OreoGaborio
      • 1285
      update: my dad found some info on roadfly..... 99% sure it's the Detent Spring.
      whatever that is
      -Pete
      • rs4pro3
        • 5808
        It's a little spring behind a bolt on the side of the tranny.
        85 325e 2.7 ITB'd stroker
        • OreoGaborio
          • 1285
          DIY?
          -Pete
          • rs4pro3
            • 5808
            If it's the thing I'm thinking of I'd say so. I started to tear apart my 85 318i tranny after it stuck into first gear, and remeber pulling off a bolt on the side with a large spring going into the cae by the shilt linkage which i think was this part.
            • rs4pro3
              • 5808
              That's the spring on my 85 318i 5 speed tranny, when I push it in I hear the gear shift clicking sound. On my m20 tranny the spring looks to be in the same spot but held in place with a large hew bolt. I'd double check though before pulling off bolts.
              • OreoGaborio
                • 1285
                thanks for the info & pics bro... but can anyone confirm that this is what's wrong?
                -Pete
                • AdamF 88iS
                  • 2051
                  Could be the spring, but usually what you said about the trasition from on-->off the gas is what will make a bad syncro pop out of gear. May as well try the spring first though, it's a lot cheaper and easier.
                  Adam Fogg- '88 M3
                  Common sense- It's the new 'gifted'
