Dinan VS AC Schnitzer (chips)
  • LowR3V'in
    • 4209
    What's the diffrence between both these chips for the 2.7?
    Thank you. :D
  • BahnE30
    • 1050
    just buy the turner
    nothing better :P
    • rs4pro3
      • 5808
      if your talking about for a 2.7 then there both copies of the original. You;d need to compare the two different engine the origanl chips were designed for to find what chip would be closest to the engine specs you building like cr ratio, and what not.
      85 325e 2.7 ITB'd stroker
      • LowR3V'in
        • 4209
        So what your saying is that they're custum chips.
        Or that they're diffrent types of 2.7 with diffrent specs, and I wont know wich chip is for what spec 2.7.. :?:
        They're both on e-bay for a buy it now of $90-$100.
        • Erick
          Official R3V Drifter
          • 11169
          They are not original chips though.
          Look around for a bit and you'll find used JC chips for 100-150.
          Can't beat that.
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • bimmerphile
            • 3495
            :rofl:
            dude, don't buy ebay chips. Honestly.
            Give me an EPROM burner, and I too can copy some stock chips and bump the redline to 7000 :roll:
            • rs4pro3
              • 5808
              There not custom just a copy. Schnitzer had a certain special chip for there 2.7 engine and this chip is just a copy of the software. And then Dinan had there own stlye engine. I'm awsuming your talking about the m20? Every tuner has there own idea of what is best. like saw for instance the Hartge H27 engine ran a 10:1 cr ratio using custom machined m50 pistons. Where as some of the other companies ran differnent ratios with most likely custom pistons. Plus they used different methods of porting the heads, different cam specs, etc, etc... You can't just go buy a 2.7 chip and expect your 2.7 to run great on it. I'd highly recomend getting ahold of Mark D. He makes custom bhips tuned to your specs. he can take a base line chip like saw the Schnitzer chip and then modify it to work with your needs. Contact Shifty at www.mye28.com to get is contact info, just ask him for the guys name for the custom 2.7 e to I chip He'll know what your talking about.
              Fred Kim on this board has had a problem with this his 2.8 ran great and then started to loose performance, this is due to the chip not being exactly designed for his engine build.
              With the 2.7i engine I was going to build i was going to go with a copy of a Harte H27 chip as it had close to the same specs except for I was going to have 1mm larger intake valves like the Hartge used.
              • rs4pro3
                • 5808
                some info about Mark's chips http://forums.mye28.com/cgi-bin/talk...&msg_num=19323
                • bimmerphile
                  • 3495
                  Right, but Ely there's no guarantee that those chips on eBay are even copies (which is the best scenario).
                  • rs4pro3
                    • 5808
                    True, they could just be a copy of a stock 325i chip but with the rev limiter raised and what not. Buying a chip for anything other then a stock Engine is risky, unless you have one custom burned. Mark's price is pretty good to considering what a proper chip can do to open up an engine.
                    • rs4pro3
                      • 5808
                      That's Mark's website.
                      • Mystikal
                        Wheel Fitment Expert
                        • 9602
                        MarkD = good chip. I have a 2nd generation M20B25 175 chip in my car, it kicks ass.
                        I was out watching him auto-x in his M5 yesterday, great guy. 8)
