Tire/wheel/suspension/offset setups that WORK
  • e30Matt
    • 5077
    Any setups that work (no rubbing, etc.), please post them. I'll put everything into a big table when I get a large enough batch of results.
    Sticky?
  • rs4pro3
    • 5808
    Et-20 16*7.5 TSW hock R rims 205/50/R16 tires Perfect in the rear, but have rubbing on the frame at full lock up front. Width wise i'm fine up front but my next tires will be 45 series to cut down on the frame rubbing.(only up front)
    Suspension
    bilstein M-tech shocks Racing dynamic springs. 21mm IC front sway bar with m3 endlinks and front and rear strut tower braces. -3 camber on both front corners.
    85 325e 2.7 ITB'd stroker
    • e30Matt
      • 5077
      Suspension setup?
      • LikeCDoos
        • Jan 2004
        • 2522
        Eibach Pro Kit/Bilstien Sports
        16x7 BBS RK's
        205/50/16 AVS ES100's
        No Rubbing
        • rs4pro3
          • 5808
          oh and 85 318i Spax 60mm drop springs stock shocks and struts. bottle caps 195/60/r14 tires No rubbing
          • C ///M
            • 1040
            IE Stg III race springs
            Bilstein Sports or Koni SAs
            IE Sways
            BavAuto Stressbar
            E46 m3 cabrio RSMs
            aluminum control arms
            offset urethane CA bushings
            17x8.5 wheels et20 front, et22 rear
            235/40R17 Yokohama AVS ES100
            Rolled Inner fender lips
            Plastic Fender lining up front adjusted so tire doesn't rub the front when turning full lock.
            332iS R.I.P.
            • rwh11385
              lance_entities
              • 18403
              16x7 BBS RK's
              No Rubbing
              Include offset ;)
              I have a similar set-up 205/50-16 ES100's on
              16x7.5 Borbet Type T's ET20
              Lowering is as you see it in sig.
              Little bit of rubbing coming out of driveway backing up and turning at same time. Very little.
              • LikeCDoos
                • Jan 2004
                • 2522
                16x7 BBS RK's
                No Rubbing
                Sorry ET25
                • Brew
                  • 3060
                  Ground Control 350f/475r w/ Bilstein sports in front and Koni SA's in rear.
                  I have the GC's set so that there is zero fender gap front and rear.
                  15x7 et25.
                  225/50-15 Yoko AVS ES100.
                  Ghetto self-rolled fenders.
                  Zero rubbing.
                  Its worth noting that the rear rubbed ever so slightly under HARD acceleration when I had the Eibach Pro-kit.
                  '91 318is
                  • MattM20
                    • 641
                    87 325is
                    H&R Sports (1.3") w/ Koni SA's
                    15x7.5 et25
                    225/50/15 yokohama avs es100's
                    • Jon325i
                      • 6934
                      Car: '89 325i
                      Shocks: Tokico Illuminas
                      Springs: H&R Sport
                      Wheels : ATS Type 10 (16x7.5, ET30)
                      Tires: Sumitomo HTRZ II (205/45)
                      Fenders rolled: yes
                      Comments: No rubbing/clearance issues
                      Pic.....
                      (totaled in Feb. 2003)
                      Jon
                      Rides...
                      1991 325i - sold :(
                      2004 2WD Frontier King Cab
                      RIP #17 Jules Bianchi
                      • KrayZE30
                        • Mar 2004
                        • 113
                        H&R Cup Kit
                        ET 20 17x7.5
                        Yoko Parada 215/40/17
                        Rolled Lip
                        Extra 10mm spring pad in the rear stacked on the stock pad.
                        No rubbing AT ALL once the spring pad was installed. This shits pretty damn close in the rear. Can hardly get my fingers between the fender and the rear tire. I LOVE IT! :)
                        • OOMPH!
                          • 3487
                          How did you actually rig the plastic?
                          • Beej '86 325es
                            • 2639
                            On a pre-88 e30, I have run:
                            ET20 225/45/16
                            ET22 215/35/18
                            Bottlecaps with 195/65/14s with 20 mm spacers
                            -Brandon
                            '86 325es S50
                            '12 VW GTI Autobahn DSG
                            '03 540i M-Sport (sold)
                            '08 Jeep SRT-8 (sold)
                            For sale:
                            S50 TMS chip for Schricks
                            • C ///M
                              • 1040
                              OK, first, I used Urethane Offset CA bushings which pushes the wheel about a half inch forward. This was necessary with my large wheel and tires or else they would probably not clear the rear of the fender well (that area is not exactly modifyable unless you take a sledge hammer to it and bend away sheetmetal). Anyway, after that, if you have rolled your inner fender lips, you probably have noticed the black plastic fender lining that has one screw in the very center of the top of the wheel well, and it's also secured at the front of the fender well. If you roll your inner fenders quite a bit, this plastic fender lining is most likely visible somewhat "hanging" down a little past the fender arch. It isn't really hanging since it is pretty taut. Anyway, this piece was somewhat secured at the edges by the inner fender lip, and now that that piece is rolled in, the fender lining may have popped out a bit like mine did, which caused it to not be secured up past the fender arch. I simply unsecured it at the front of the fender well and readjusted it so that it was back up inside the fender arch and then secured it with a screw at the front of the fender well. Hopefully you know what I am saying, basically if you do rub, found out which point touches and adjust it. Since the front of this fender lining rubbed, and it's moveable, I just readjusted it and then resecured it.
                              332iS R.I.P.
