stalling :-(
  • german g
    • Feb 2006
    • 1608
    stalling :-(
    last night , my car started stalling, It has new plugs/wires/rotorcap and im hoping its maybe bad gas. It will run fine and then bog down for a few mins., (doesnt want to rev up beyond 3k) adn then run perfectly fine for a while. I drove it again this morning and it seemed fine and then bogged down again. It didnt have much gas, so i filled it up, hoping it was just the gas gremlin (its not). I also just changed the air filter (thiniing that might be it), still bogs down...
    help me guys :-)
    90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
    :firehop:
    Is the fuel pump making noise? A failing pump can cause the symptoms you describe.
    • german g
      • Feb 2006
      • 1608
      I cant hear anything, but I'm gonna investigate closer tonite.
      thanks
      :firehop:
      • mattdk318i
        • Jun 2006
        • 3953
        has its overheated lately?
        • SchnellerVert
          • Sep 2005
          • 3948
          Sounds like a fuel related issue.
          • german g
            • Feb 2006
            • 1608
            It did about 2 months ago, but I replaced the Thermostat and housing, and it ran fine.
            :firehop:
            • dark89e30
              • 263
              Sounds like a fuel filter to me. When the car sits for a while, all the particles settle inside the filter so it will run briefly when you restart. Replace it. But you might want to checkout the FPs prefilter in the tank too...
              • german g
                • Feb 2006
                • 1608
                hmmm, that might be it too, suck its like 100 degrees, no way im working on my car in this shit!!!!!!!:hitler:
                :firehop:
                • cnardinola318is
                  • May 2007
                  • 30
                  what did you do?
                  this is happening to me.
                  91 318is New Orleans Lives
                  www.nolatonight.com
                  • strad
                    • Jan 2007
                    • 241
                    wiggle the fuel relay and main relay around a bit, or even remove them and clean off any tarnishing you see on the contacts. Couldn't hurt, and has been known to solve this type of problem in the past. This problem reared its ugly head on my car, and after replacement of the fuel pump relay the problem has not reappeared.
                    The current fleet:
                    1992 325ic: 148k-171k miles
                    1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                    1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                    • Midnight Sun
                      • Jan 2007
                      • 429
                      Which relay's are which.
                      It doesn't say in the manual.
                      Originally posted by Teaguer
                      Filling an Eta's tank with super unleaded will reach the cars maximum attainable performance level .
                      Aa a bonus filling the tank will also double any Eta's resale value .
                      • JoeP
                        • Mar 2005
                        • 150
                        Read the Bentley. The fuel is a 4-prong and the main is a 5-prong. The Bentley lists the wire colors for the fuel relay plug so you can make sure you have the right one. I don't have it handy or I'd check for you.
                        • Midnight Sun
                          • Jan 2007
                          • 429
                          Thanks.
                          Arg.
                          Such a frustrating problem. It is sort of comforting to know that others are having the same issue.
                          Hey German, when you rev it out past 3k, what does it do? Mine makes a very specific rhythmic fluttering sound... It almost sounds like a dying woofer. Mine does it soo randomly.
                          • german g
                            • Feb 2006
                            • 1608
                            it ended up being my injectors, i put some different ones in and it is running like a champ...
                            :firehop:
