Running rich and Idle problems
  • Dinnertime
    • Aug 2007
    • 17
    I'm having a problem with running rich and a rough idle SOMETIMES. Its fine one minute and then it will drop and stall out. This all comes after A/c removal/valve ajustment (all in spec), plugs,wires,rotor,distrib cap. Any suggestions?
  • parkerbink
    • Jun 2004
    • 10138
    In order of my bet (not necessarily correct)
    AFM, 02 sensor, ground. I'd check grounds, 02 sensor & then do an AFM. Do you have a CEL? if so what code?
    • Dinnertime
      • Aug 2007
      • 17
      Throwing no codes. I'm new to E30's so im running into more and more problems. I don't know when the O2 sensor was last changed, but im going to test it before changing it.
      Were are all the grounds?
      • E30 Reaktionär
        Site Manager
        • 14451
        Sounds about like mine was doing. Mine was the AFM and bad plugs.
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • Dinnertime
          • Aug 2007
          • 17
          just changed the plugs.
          I'm thinking its something to do with the A/c removal. It had fuel going into hardlines into a a/c line then back to the fpr on the rail.
