No coolant coming out of block
  • brandondan1
    • 1091
    Just flushed and bled the coolant system today with the help of jw_325ic, because its been acting weird. When I took out the block drain plug, NO coolant came out, even with the car running. Is that normal?
    Also, the drain plug was only about an half inch long, and at the end it looked almost as if it was chipped off. I dunno, maybe part of the thread is stuck in the block..
    Anyone know why this would happen?
    91 318is
  • Wishno87
    • 6025
    the plug is just really short, i pulled mine yesterday. when i did it though coolent shot out sidways and got everywhere though. try unscrewing the overflow bottle cap
    • brandondan1
      • 1091
      Thanks for the suggestion
      I took the cap off, opened the bleed screw, and let the car run. While it helped to drain coolant from the radiator, the block remained bone dry.
      91 318is
      • golde30
        • 11464
        that is umm, strange. you sure you're taking off the rite bolt? did you stick anything into the opening to make sure its not blocked?
        IG: @Baye30
        • bmwpower
          • 1556
          pict of bolt?
          When was the last time you drained it? Sludge in the bottom of your block keeping it from draining?
          89 325is track project / 05 x5 / 99 M3
          E30 stuff for sale | Parts I'm looking for
          • rcko
            • Mar 2007
            • 295
            The bolt is short and I think it uses a 19mm socket? It is kinda aft on the block by the #5 or #6 cylinder.
            It should shoot out coolant quite forcefully.
            - 0.05s and 0.1s FTW!!!
            • Jean
              • 18228
              Yep, it would probably take a pretty thick layer of sludge too..
              Mine started leaking coolant out of the block w/o much effort at all, looking up the passenger side..
              • JasonC
                Site Manager
                • 14451
                What he said..
                1992 BMW 325iC
                1978 Chevrolet Monte Carlo
                • Massive Lee
                  • Sep 2006
                  • 6785
                  19mm? I am sure it is not the drain bolt as it is smaller. The drain plug is located on the passenger side and has disastrous effects when getting loose. It is very short too.
                  massivebrakes.com
                  • brandondan1
                    • 1091
                    wow, thanks for all of the replies.
                    I suppose it 'could' be the wrong bolt, but it is 19mm, located on the passenger side of the block, is very short, and I followed the description of my bently manual. I don't know why there would just be a random 19mm bolt on the block not holding anything up. I did this job last year and it drained fine :(.
                    I guess there could be a shitload of sludge or something blocking it, but now that the system is full(as full as I could get it), I'll try to just loosen it alone, start up the car, and see if anything comes out. If not, I'll stick something inside it and see what that does.
                    Thanks, I'll let you know how it goes tomorrow morning.
                    91 318is
                    • NOMAD
                      • Feb 2007
                      • 1502
                      So how did it go?
                      I had coolant and head issues and mine was dry when I opened it up yesterday. The only fluid that came out was from the rad.
                      '74 2002 - Build blog at
                      nomads2002.blogspot.com
                      • HST
                        • Jan 2006
                        • 757
                        how much coolent / water did it take to fill it up?
                        Originally posted by KingB
                        Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                        • brandondan1
                          • 1091
                          It took about a gallon to fill it up, (one of those prestone 50/50 bottles). I haven't had a chance to troubleshoot it yet. My jack crapped out on me, so I can't lift the car until I get a new one. =/
                          Did you try sticking something in the hole?
                          91 318is
                          • Teaguer
                            • Sep 2004
                            • 6167
                            Haha . :D
                            • NOMAD
                              • Feb 2007
                              • 1502
                              Try pouring the water in through the upper radiator hose so it goes right into the block. I fille dthis up with a gallon or so, then installe dthe hose to rad and filled up the rad with half gallon till it came out the purge hole.
