M30 AFM too big?
  • skylerwaite
    • 110
    M30 AFM too big?
    I can't seem to fit the rubber intake boot over the back of the M30 AFM. The opening is so big that the boot fits perfectly inside of it. I'm sure a reducer would be a simple fix, but I'd rather not spend more money. If this should work then I will try harder tomorrow, but for tonight, I give up.
    Also, this is a direct bolt-on, correct? I saw some write-up where a guy switched out the electronics from the M20 to the M30. Is that really necessary?
    1989 Cadillac Brougham BLOWN UP
    2000 Volvo S70 GLT SE SOLD
    1987 Schwarz 325i 107k SOLD
    1984.5 Volvo 242 Ti ABANDONED
    1999 Fern Green M3 SOLD
    1991 RT4WD Civic Wagon WINTERWAGEN
    2004 Audi A4Q 3.0 WIFEY'S
    2009 BMW 135i SOLD
    2008 BMW 135i MINE
    Originally posted by JGood
    anyone who pays $200 for a tank that refills oil instead of just fixing your oil leak, needs their head examined.
    • 37833
    You have to stretch the boot to fit, a heat gun or blow dryer is your friend.
    If your AFM's part number ends in 027 it is plug and play. You'll probably have to play with the adjustment to get it just right though, I know I did.
    Grover Beach, California
    BimmerHeads.com
    • skylerwaite
      • 110
      Ok, sounds good then.
      I probably won't adjust it at all without a AFR gauge unless it runs really awful. In which case I will probably just put the old one back on until I can scrounge up some moneys for that.
      Thank you!
      2009 BMW 135i SOLD
      2008 BMW 135i MINE
      • HST
        • Jan 2006
        • 757
        You should not need anything else to get the 027 to work. Make sure that your boot is in good shape, nice and flexy, or it will rip. It can be a bitch to stretch.
        Originally posted by KingB
        Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
        • skylerwaite
          • 110
          I have a brand new one and it's pretty stiff.
          2009 BMW 135i SOLD
          2008 BMW 135i MINE
          • dark89e30
            • 263
            All you really need to do this is a small flathead screwdriver and at the extreme, some silicon spray (wet or dry). But It sounds like your hands are too soft, so you're better off paying someone else to do it.
            • skylerwaite
              • 110
              You moisturize?
              2009 BMW 135i SOLD
              2008 BMW 135i MINE
              • Mystikal
                Wheel Fitment Expert
                • 9602
                1. Place AFM end of boot in some HOT water.
                2. Jerk off for 10 mins.
                3. Wash hands.
                4. Grab screwdriver.
                5. Use screwdriver to help now pliable boot over AFM flange.
                6. Jerk off again over the sheer awesomeness of my procedure.
                Jay
                • dark89e30
                  • 263
                  You moisturize?
                  Only my right hand (I put my afm on with my left).
                  • skylerwaite
                    • 110
                    I have concluded that this is impossible. I even put it in boiling water. Reducer it is.
                    2009 BMW 135i SOLD
                    2008 BMW 135i MINE
                    • skylerwaite
                      • 110
                      Ghetto fabulous.
                      2009 BMW 135i SOLD
                      2008 BMW 135i MINE
                        • 37833
                        Hey, if it works it works.
                        BimmerHeads.com
