Well I spent all day today and yesterday installing the stroker. Its in, and running beautifully. Took a couple starts for the ecu to adjust, but now that its been drivin for a bit, it comes to a nice idle at about 800 rpm. Haven't really had a chance to do much power testing though since I need to break it in. However, since I needed to seat the rings, I took it up to about 5500 rpm several times, and boy, what a difference. The low end torque in this is great, can't wait to get this thing on the track. I was also pleasantly surprise by how well it did after 4500 rpm. The cam (274) really shines at these rpm's so it still has the great punch from 4500 up (although I couldn't take it to redline I can tell its going to be awesome). Unfortunately, I was doing most of the work myself and couldn't take any pictures. I'll take a few of the engine in tomorrow.
The Stroker is in, finally!
Originally posted by modifiede30I was still under the car at 6. After everything was in, I found the oil distribution housing was leaking, so I had to fix that, didnt' finish until about 6:30. Wish I could've gone. Next time, its right around the corner from me.
What matters is that your car is rocking! :D And I can't wait to hear it and see pics.
Good new! can't wait to see pics. So what did you end up using for a chip? I still can't make up my mind about a 2.7i or an m30 swapDriving is the only way to go faster....
Please let me know what you find out, as I may go the super eta piston route if I decide to continue building the engine or not.Driving is the only way to go faster....
Ya I realy don't want to do any blocking or shaving. There is one other option I could go which would be the same piston, rod, and crank setup as the Hartge H27 but it would have a the long stroke crank, with the I 135mm rods, but Lighter pistons. And I could use stock pretty common parts.
I realy wanted the Euro pistons but you know the story behing those :roll:85 325e 2.7 ITB'd stroker
