how often or after how many miles should change ur timing belt
    its on an 95 525 i that has 130 000 miles... ive herd something abour after a 100 000 or so u should change the timing belt... is that true ,and how diffcult is the job what should look for expect?
    <img src=http://www.r3vlimited.com/board/image.php?u=14143&dateline=1175417424&type=profile >
    uhhhh. there is no timing belt on that car. it has a chain. go to realoem.com and look at the engine pics.
    IG: @Baye30
      That engine has a chain, like he said. And, chains normally don't require changing.
      - Sean Hayes
        thanks for the infor i thought it was a belt
          Sometimes the chain tensioner will get weak, causing extra noise (and wear) on the chain and rails. That's the thing you need to stay on top of with your timing system.
          The current fleet:
          1992 325ic: 148k-171k miles
          1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
          1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
            the the car runs great it was just a precaustion anyone loking forone
              Yeah some mechanical tensioners get changed out for hydraulic ones, at least on the M54.
              http://www.cardomain.com/ride/657387
