So I've got m50 with eta transmission, i was running s50 flywheel/clutch and starter. I had a very bad squeal when the engine turned over and then when it started it went away, so more noise. I figured it was just incompatible with the e trans. so,
I pulled the transmission (which was good as i found out I had the wrong pilot bearing) and installed a 325i single mass flywheel and clutch, and put in my old e starter (the big one).
I figured this would take care of my noise problem. Well, it got a lot worse and I have no idea how. I shaved the oil pan I know its not hitting. When I turn it over it makes a horrible gear mesh noise but once started it sounds perfect. I have no idea whats going on here.
