I have a 1990 325is and I'm wondering whether to use synthetic oil. I also have a 1997 328i in which i use Mobile 1 Synthetic oil that works great. I heard from a friend that it is not always good to use sythetic oil on the e30. Does anyone have any input on this issue? Thnx in advance.
Sythetic Oil??
Originally posted by erik325i View PostIt depends. If your motor already leaks some oil, switching to synthetic will only make it leak more. If you have a great motor with no leaks and whatnot, synthetic should be great for your motor.
-ErikOriginally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
